Author Topic: 2x spacebar profile  (Read 2158 times)
Offline qihqi
2x spacebar profile
« on: Tue, 28 October 2014, 17:32:46 »
Hi,
Does anyone know where to get 2x keys with spacebar profile (curves out, instead of in) like the space bar used here (http://planckkeyboard.com/)
Offline FrostyToast
  • Litshoard
Re: 2x spacebar profile
« Reply #1 on: Tue, 28 October 2014, 17:34:44 »
You could use a blank num0 key.
It might be a bit weird to get a hold of but it should work quite well. Especially if you flip it like what was shown in the pic.
Quote from: elton5354
« Reply #2 on: Tue, 28 October 2014, 18:39:35 »
I have never seen with Space Bar-profile for Cherry MX. I filed a thick Row A-profile numpad-0 key into a Space Bar, but it is very thin in places and doesn't have the right surface texture.
Offline qihqi
« Reply #3 on: Tue, 28 October 2014, 18:40:25 »
Thanks! How do you flip the key like the one in the picture?
Btw I thought num0 key has similar profile as Ctrl but just bigger?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Wed, 29 October 2014, 00:05:17 »
I don't know of anywhere than makes convex type smaller than 3x units. To flip a key, do just that and place it upside down.
Offline qihqi
« Reply #5 on: Wed, 29 October 2014, 14:14:07 »
Thanks! I am an idiot.
