Author Topic: does a 103 or 104 key Trackpoint IV usb keyboard exist?  (Read 2368 times)
Offline jaynyc
« on: Tue, 28 October 2014, 19:28:16 »
Hi.  Does a 103 or 104 key Trackpoint IV usb keyboard exist?
Offline 0100010
  • Not Sure
Re: does a 103 or 104 key Trackpoint IV usb keyboard exist?
« Reply #1 on: Tue, 28 October 2014, 21:20:30 »
Not sure if this is what you are looking for?  http://pckeyboard.com/page/EnduraPro/UB40PGA
Offline FrostyToast
  • Litshoard
« Reply #2 on: Tue, 28 October 2014, 21:24:00 »
If you want to be really fancy beyond the trackpoint, then there are Model M keyboards with trackballs (completely different from the trackpoint, but definitely something to consider)
Quote from: elton5354
« Reply #3 on: Tue, 28 October 2014, 23:04:50 »
They are the M5 series, featuring the M5-1 and M5-2. One has a trackball in the top right, the other near the arrowkeys. Unicomp made the top right trackball version for a while, and it seems to be much more common.
As far as the existence of such a keyboard; sethstorm converted his 122-key model F to have a trackpoint module. You can do the same.
