Author Topic: [IC] Out of the Vault - Series II: Vault 101 + 13, Nuka Cola (GB over)  (Read 72842 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: [IC] Out of the Vault - Series II: Vault 101 + 13, Nuka Cola (PMK IC is LIVE!)
« Reply #100 on: Tue, 09 December 2014, 11:05:22 »
Work PC.  I think it's just from my browser resampling the image.  I opened the full size mock-up and they look OK.
http://www.pimpmykeyboard.com/wp-content/uploads/2014/12/ParentMockup1.png (Warning: LARGE)
Still not as sharp this, but good enough for key caps.
We tried and tried to get it to be as solid as that, but there are severe limitations on ABS Doubleshots...
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline Data
« Reply #101 on: Tue, 09 December 2014, 13:35:55 »
Yeah, I figured that was part of it.  No biggie.  The caps are so small that the minor differences won't be visible and it's still instantly recognizable.
Offline mogo
« Reply #102 on: Tue, 09 December 2014, 13:42:49 »
I had to widen many of the gaps and loops in the letters (like in the "a", "l", and "o" characters) and I completely opened the "k" character  because it looked horrible when I tried to inflate the loop to the minimum diameter. They need a certain amount of gap because of how ABS shrinks when it sets and cures. We also had to thicken all the lines because, again, if the letters were too thin they'd shrink and split (or something like that). All the work was done in illustrator, so it is vector work, not raster, and I think it'll look fine as a finished product.  :thumb:
Offline 00zeRO
« Reply #103 on: Tue, 09 December 2014, 14:46:40 »
Trust me everyone, Mogo and I had a time tweaking this legend to get it to specs. IMHO it is better than good enough. Mogo single-handedly saved this legend from being completely lost. I thought there was no hope for it and would have given it up completely. And I have to admit my patience with the tweakage ran extremely thin, if you can't tell, haha. Thanks again, Mogo!
Offline 00zeRO
Re: [IC] Out of the Vault - Series II: Vault 101 + 13, Nuka Cola (Please vote!)
« Reply #104 on: Tue, 09 December 2014, 22:06:37 »
Edit to OP...complete with vote counter!
Offline skrotnisse
« Reply #105 on: Wed, 10 December 2014, 07:34:52 »
Voted! Need this!
And, can I use the GB-banner to promote this? And, can anyone tell me how to add it to my posts - I'm a übernoob!
Offline mogo
« Reply #106 on: Wed, 10 December 2014, 13:55:59 »
You can go to your forum profile and add the following:
Code: [Select]
[url=http://www.pimpmykeyboard.com/deals/out-of-the-vault-inspired-by-fallout-series-ii-nuka-cola-and-vault-101-sa-row-3-double-shot/][img]http://i.imgur.com/7oyJ8Jt.png[/img][/url]
« Last Edit: Wed, 10 December 2014, 17:15:56 by mogo »
Offline Data
« Reply #107 on: Wed, 10 December 2014, 16:05:45 »
Code: [Select]
[img width=350 height=19]http://i.imgur.com/Zhk915J.png[/img] [url=http://www.pimpmykeyboard.com/deals/out-of-the-vault-inspired-by-fallout-series-ii-nuka-cola-and-vault-101-sa-row-3-double-shot/][img]http://i.imgur.com/7oyJ8Jt.png[/img][/url]
You left your personal image in there too, FYI.  Should just be this bit:
Code: [Select]
Offline mogo
« Reply #108 on: Wed, 10 December 2014, 17:15:44 »
Correct sir. I was doing it all from my phone. Whoopsie. :P
Offline Data
« Reply #109 on: Wed, 10 December 2014, 19:38:57 »
Great job with the image, by the way.  ;D
Offline mogo
« Reply #110 on: Wed, 10 December 2014, 22:21:29 »
I've fixed the mockup on the polycarbonate keycap because the doubleshot actually goes partially down the inside of the key, so you wouldn't see the stem so easily.
[/right]
Banners can be adjusted accordingly:
Code: [Select]
[url=http://www.pimpmykeyboard.com/deals/out-of-the-vault-inspired-by-fallout-series-ii-nuka-cola-and-vault-101-sa-row-3-double-shot/][img]http://i.imgur.com/57Ihlfv.png[/img][/url][/right]
Offline 00zeRO
« Reply #111 on: Thu, 11 December 2014, 11:25:29 »
We are at 34 votes already, can you believe it! Thanks to everyone who plans to participate in this GB!
Offline skrotnisse
« Reply #112 on: Thu, 11 December 2014, 11:54:16 »
I got a Nuka-Cola spacebar. So I need this!
Offline 00zeRO
« Reply #113 on: Thu, 11 December 2014, 12:47:24 »
And I need one of those...donations are accepted...  :p
Offline beltet
« Reply #114 on: Thu, 11 December 2014, 17:01:27 »
I would voted today if SP could fix pmk so you can use on a phone. Anyway will vote later on. Want this parent deal.
Offline ideus
  • Björkö.
« Reply #115 on: Fri, 12 December 2014, 07:22:44 »
I'd be in if it were a DSA set,  without hesitation.
I also suggest you to offer it as a child set in some of the upcoming SA full sets.
Offline 00zeRO
« Reply #116 on: Fri, 12 December 2014, 07:31:06 »
Offer DSA as a child set? Unfortunately, these legends are SA only...but I may consider it
Offline 00zeRO
« Reply #117 on: Fri, 12 December 2014, 13:20:22 »
Updated numbers on the votes...we are now at 44. Six more and we go Live with the GB!
Thanks again to all who have voted, and keep them a comin'!
 :thumb:
Offline skrotnisse
« Reply #118 on: Fri, 12 December 2014, 13:27:07 »
Have you posted on r/mk?
Offline 00zeRO
« Reply #119 on: Fri, 12 December 2014, 13:29:10 »
PMK will, or should I say, should...
Last time I did so, it was kinda like spam...
If you like, you may...every little bit will help.
Offline skrotnisse
« Reply #120 on: Fri, 12 December 2014, 13:51:51 »
Done!  :thumb:
Offline 00zeRO
« Reply #121 on: Fri, 12 December 2014, 13:55:34 »
Done!  :thumb:
And Vault Boy gives you the  :thumb:'s up!
Thank you, sir!
Offline 00zeRO
« Reply #122 on: Fri, 12 December 2014, 16:39:39 »
Okay all! We did it. Now it is just a matter of time before this GB goes live!  :thumb:
Offline mogo
« Reply #123 on: Fri, 12 December 2014, 21:53:15 »
64 votes, hot stuff!
Offline Rotaku
  • Too Based
« Reply #124 on: Mon, 15 December 2014, 08:02:27 »
So ready for this to happen :D
Not toooo active on GH anymore, if you need me, shoot me a PM on Reddit! /u/IchibanXD
Offline 00zeRO
« Reply #125 on: Mon, 15 December 2014, 08:28:53 »
Me too. SP is a little slow right now
Offline dimmu
« Reply #126 on: Wed, 17 December 2014, 18:08:29 »
voted. i really hope we get 100 votes soon!
Offline 00zeRO
« Reply #127 on: Wed, 17 December 2014, 18:51:26 »
No need. It only needed 50. SP is just being slow
Offline dimmu
« Reply #128 on: Wed, 17 December 2014, 20:26:36 »
awesome. i'm getting excited already!
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #129 on: Thu, 18 December 2014, 03:03:49 »
Voted  :thumb: .
Anything to do with the SA profile I'm there.
Offline 00zeRO
« Reply #130 on: Thu, 18 December 2014, 07:01:04 »
I plan on doing most of my designs in this profile: SA Row 3. It looks to be the hottest thing right now and there are virtually no novelties for this profile
Offline taylordcraig
« Reply #131 on: Thu, 18 December 2014, 11:25:00 »
will we be seeing the child buys?
Offline 00zeRO
« Reply #132 on: Thu, 18 December 2014, 12:37:56 »
In the Group Buy, yes.
SP told me that they are unable to make Child Deals under the Parent Deals in the Interest Checks. Good to go in Group Buys.
Offline Rotaku
  • Too Based
« Reply #133 on: Thu, 18 December 2014, 23:55:14 »
Just picked up the base set + nuclear data orange set  :thumb:
Offline mogo
« Reply #134 on: Fri, 19 December 2014, 01:04:29 »
One of everything for me.  :p
Offline Heliosphere
« Reply #135 on: Fri, 19 December 2014, 01:19:59 »
I added 4 total sets and shipping is $15. I hope that's not the actual shipping cost for about 13 keycaps.
Offline 00zeRO
« Reply #136 on: Fri, 19 December 2014, 06:58:29 »
I hope it isn't either...but what they may be doing is sending them our in color production waves. i.e. parent deal ships when ready, then nuclear data Green ships when its ready and so on
Offline Data
« Reply #137 on: Fri, 19 December 2014, 09:17:00 »
Didn't know this was live.  I rarely look at the first page.
Purchased base, green, and orange kits.  Nice job Zero & Mogo.
Offline mogo
« Reply #138 on: Fri, 19 December 2014, 15:56:30 »
Ouch. I was really hoping that shipping wouldn't be so outrageous. Unfortunately, what you're saying makes sense.
Offline 00zeRO
« Reply #139 on: Fri, 19 December 2014, 23:22:35 »
What I said is not confirmed however
Offline Heliosphere
« Reply #140 on: Mon, 22 December 2014, 16:30:33 »
Bob, the stand-in for Melissa, responded to my inquiry confirming that the shipping estimate will be the actual shipping and handling charge. I'm not willing to pay $3-4 shipping per child deal so I'm sticking with the main set. This might mean the child deals are not likely to make it through.
Offline 00zeRO
« Reply #141 on: Mon, 22 December 2014, 17:02:21 »
Personally, the only one I want to see made is the Irradiated Vaults...did Bob happen to tell you if they will be shipped together or each deal as it is produced?
Offline Heliosphere
« Reply #142 on: Mon, 22 December 2014, 17:09:44 »
He didn't specify. Should I ask?
Offline 00zeRO
« Reply #143 on: Mon, 22 December 2014, 17:19:25 »
I just hit them with the hard question...it is the only thing that would make any kind of sense. I don't think pretty sure they don't want to extort shipping money from customers.
Offline 00zeRO
« Reply #144 on: Mon, 22 December 2014, 17:20:30 »
By the way, check out my GB thread over in SP land on here. I will begin the discussion with SP in an open thread forum topic.
Offline 00zeRO
« Reply #145 on: Tue, 23 December 2014, 06:02:36 »
A disclaimer has now been added to each child deal on PMK. SP will work with the shipping on the child deals if you buy multiples and request it.
Offline 00zeRO
« Reply #146 on: Tue, 23 December 2014, 07:46:58 »
It reads as follows:
*depending on the size of your order, we can refund the duplicate shipping when requested*
Offline mogo
« Reply #147 on: Tue, 23 December 2014, 10:21:50 »
Well, since I'm getting one of everything, if everything ships out at once, you can be darn sure I'm going to make a request. :O
Offline Bakgrund
« Reply #148 on: Thu, 01 January 2015, 14:41:23 »
I'm really interested in the parent set, Irradiated vault set and the Nuclear data green set, however I just wondered where I request a refund for the duplicate shipping cost, and how big of an order I'd have to make to get a refund?
Quickfire Rapid    Quickfire Rapid
Mx Browns          Mx Reds
Ducky thick PBT   Stock caps
Offline 00zeRO
« Reply #149 on: Thu, 01 January 2015, 16:21:19 »
Well, I am pretty sure that they will refund you for any extra shipping beyond the first deal you purchase. You should email at their contact link www.pimpmykeyboard.com
