Author Topic: [IC] Out of the Vault - Series II: Vault 101 + 13, Nuka Cola (GB over)  (Read 72844 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: [IC] Out of the Vault - Series II: Vault 13 NukaCola?
« Reply #50 on: Mon, 10 November 2014, 10:10:28 »
Okay, so I just got the go ahead to use the double zero keycap legend from Samwisekoi. I am considering doing a full matrix of color choice with the Vault 13 legend, double zero legend, and a new vault 101 legend (once I finish it). I am thinking of having individual options available with their own MOQ's, like the way that Ivan does his GB's. If it tips, it goes, if not, it won't.
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline mogo
« Reply #51 on: Mon, 10 November 2014, 12:32:17 »
That sounds exciting! I can't wait to see mock-ups of all these things. (And if you want help making said mock-ups, you can always PM me! ;D)
Offline 00zeRO
« Reply #52 on: Mon, 10 November 2014, 12:49:13 »
You know it.
What do you think about doing GLID legend with a Blue PC keycap?
By the way all these keycaps that I plan on trying to do will be SA profile.
Offline mogo
« Reply #53 on: Mon, 10 November 2014, 16:40:15 »
I personally think SA is fun and interesting, but i've never typed on a full set of it yet, and the SA/DSA hate on the forum is starting to bubble up because so many recent sets have used it. (At least, from the vocal complaints in the "unpopular opinions" thread, hating SA/DSA seems to be not-so-unpopular)
What do you mean PC keycap?
Offline 00zeRO
« Reply #54 on: Mon, 10 November 2014, 16:48:00 »
PolyCarbonate! The coolest clearest most totally awesome substance by which keycaps are made! It would totally have that Glowing Bottle effect, I think.
Offline FrostyToast
  • Litshoard
« Reply #55 on: Mon, 10 November 2014, 16:49:04 »
Backlight compatible Pip boy maybe?
It would be sweet if it looked like there was a screen that turned on.
Quote from: elton5354
Offline mogo
« Reply #56 on: Mon, 10 November 2014, 16:51:14 »
Can you link to any images or examples? It's not something that Sig. Plastics does, is it?
Offline FrostyToast
  • Litshoard
« Reply #57 on: Mon, 10 November 2014, 16:52:25 »
Not the best photo of it, but this is what I could find
Offline 00zeRO
« Reply #58 on: Mon, 10 November 2014, 17:05:29 »
Yes...all of keypop's keycaps are made by SP. The ones in the picture of the portal keycaps were also made by SP. Thanks Frosty, I actually own those.
Anyways, what if we could get a GLID legend with that blue polycarb over it in SA fashion. Can you say empty glowing bottle? Amiright?
Offline mogo
« Reply #59 on: Mon, 10 November 2014, 17:06:59 »
Ahhh. Seeing the first shot through the polycarb is a bit weird, but it could be very cool!
Offline FrostyToast
  • Litshoard
« Reply #60 on: Mon, 10 November 2014, 17:08:18 »
I don't play Fallout at all, but I would get on this!  :thumb:
Offline 00zeRO
Re: [IC] Out of the Vault - Series II: Vault 13 + Nw Lgnds & ND/RH/GLID Relegends
« Reply #61 on: Thu, 13 November 2014, 20:05:55 »
Just added mockups to the OP.
 :cool:
Offline kalrand
« Reply #62 on: Thu, 13 November 2014, 21:46:18 »
 :cool:
Can SP do doubleshot PBT?
My 122 key Model M was born on July 25th, 1988.
Offline Data
« Reply #63 on: Thu, 13 November 2014, 21:57:59 »
 :cool:
There's a rumor that they have some of the tooling, but if you ask them they'll say no.
Only dye sub, pad print, and blank options for PBT from SP.
Offline 00zeRO
« Reply #64 on: Thu, 13 November 2014, 22:34:36 »
Offline mogo
« Reply #65 on: Thu, 13 November 2014, 23:15:42 »
Offline FrostyToast
  • Litshoard
« Reply #66 on: Thu, 13 November 2014, 23:22:05 »
Offline mogo
« Reply #67 on: Thu, 13 November 2014, 23:28:43 »
Yeah! I based the 'shop off of the color and appearance of the novelty Cloudy keycap from keypop that I own.
Offline 00zeRO
« Reply #68 on: Fri, 14 November 2014, 06:31:01 »
One word: awesome!  :eek:
Offline 00zeRO
And the planning goes on-n-on
Offline chrisq
Please add relegendables to the buy.
I'm looking for VV (nuclear) green and vault blue in 2x and 1x.
Offline 00zeRO
Quote from: chrisq link=top ;)ic=64963.msg1536383#msg1536383 date=1416042815
Berzerkfan is doing them Iin his white/other color IC thread. I don't want to step on any toes. And, in truth I want to but he started his thread first.  :-X
« Last Edit: Sat, 15 November 2014, 07:22:33 by 00zeRO »
Offline chrisq
According to his last post he now seems to have dropped it and is going for blanks witha label printer  :confused:
Offline 00zeRO
See OP. Relegends will now again be considered with this GB for those who missed out on the Nuclear Data ones, or if people want some to match their companion sets.  :thumb:
Offline 00zeRO
Re: [IC] Out of the Vault - Series II: Fallout 3 legends (Planning)
« Reply #74 on: Tue, 18 November 2014, 11:31:00 »
Okay, since I feel like Ross Perot and am going in and out about the relegendables, I have decided to create a separate IC and GB for them. You can find the current IC here.
Offline Data
« Reply #75 on: Tue, 18 November 2014, 11:36:41 »
Ross Perot...
Offline 00zeRO
New Mockups! :)
Offline Mr. Perfect
In Fallout 3 and F:NV you access the Pip-Boy with the Tab key. Would it be cool to have a Tab key that said Pip-Boy? I'm not sure if that would just be annoying or not...
Oh, and just out of curiosity, is 8 teeth around the Vault logo the smallest level of detail that SP can do? In game it's 12 teeth.
« Last Edit: Fri, 21 November 2014, 07:17:27 by Mr. Perfect »
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline 00zeRO
Not sure...I play them on console. I do know tab would be more expensive. Not a bad idea. Thank you
Offline 00zeRO
Keep the thoughts and ideas coming. IC on PMK coming soon. At this point I pretty set on the current mockups in the OP. Only question I have would be should there be Nuclear Data Green versions offered with this set? I am not really feeling the Green and White vault legends myself. What you all think?
Offline Mr. Perfect
I'm not sure why this didn't occur to me before, but how about the logos of the different factions in the game? Brotherhood of Steel, Enclave, NCR, Ceaser's Legion, etc. They all have a smart little logo, along with lots of the smaller groups, companies and locations.
Also, it looks like you responded to my other post while I was editing it. Any way to get the 12 teeth on the vault logos, or can't SP do details that fine?
Offline 00zeRO
Each in their own series. This one builds upon the last one. The next one will build upon this one and so on.
Concerning faction logos, a lot of detail and risk of trademark infringement is what is keeping me away from them. These are ABS doubleshots with simple legends. Who knows what will be available in series III?
As for the vault 'gears,' I suppose 12 teeth would look great and thanks for the idea. I like the overall simplicity of the vault symbols as they are now. Besides the Series I Vault 13 keycap sold over 200 and tipped twice, so I must have done something right in the initial design.
Thanks for the ideas, future sets will likely feature some elements of what has been suggested so far.
Offline Data
Sexy.
Offline 00zeRO
Sexy.
Very nice...and it will become rare too. Round 2 will feature newly designed larger (unflawed) legend.
Offline 00zeRO
Polishing the GB for PMK...let me know if any of the color choices are a bad idea for the child deals. Check OP for edit mockups thanks to Mogo.
 :thumb:
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
Looks good.
Offline mogo
Having the parent and child deals all laid out makes everything much easier to understand.  :thumb:
Offline Data
Just checked the OP again. Looks great man. Can't wait.
Offline 00zeRO
Just to give an update, everything is set to go to IC on PMK. This darn Nuka Cola keycap is being a real pain in trying to shape it to the right sizing for Doubleshootiness ('s a word). Mogo and I are bouncing that one back and forth like a tennis ball.
Offline 00zeRO
Keep your eyes glued to PMK for IC going live very soon...just as soon as I get a chance to update the Nuka Cola approved legend on the mockups for OP and IC on PMK.
Way to many acronyms. I only use them so that people don't <tl:dr> me
Offline mogo
Yessssss. Another opportunity to lighten my wallet. :D
Offline 00zeRO
Edit to the OP...now it will be only a little while before we go live with either IC on PMK first, or directly to GB...I am still waiting for SP to give me an answer.
 :cool:
Offline Heliosphere
Damn those mockups are sexy. I want every one of them, you hear me? Every. One.
Offline mogo
Glad you like them! I'm excited too and I want lots of SA caps :D
Offline 00zeRO
Edited OP...IC is now live on PMK!
Woot!
 :p
Offline FrostyToast
  • Litshoard
Voted! Hope this becomes a reality!
Offline 00zeRO
And I hope Melissa fixes all those Gorram child deals that were erroneously (on their end) posted as Parent IC's...
Offline Data
Is it just me or do the Nuka Cola legends look a little rough on PMK?
Offline 00zeRO
Are you on your phone or PC?
Offline Data
Work PC.  I think it's just from my browser resampling the image.  I opened the full size mock-up and they look OK.
http://www.pimpmykeyboard.com/wp-content/uploads/2014/12/ParentMockup1.png (Warning: LARGE)
Still not as sharp this, but good enough for key caps.
