Author Topic: Lubing Topres (HHKB Type-S)  (Read 1472 times)
Offline Sygaldry
  • Edema Ruh
« on: Thu, 30 October 2014, 15:47:04 »
I'll be receiving my HHKB Type-S soon and had a couple questions:
First, in the event that I get a whistling Type-S, will lubing help get rid of the sound?
And second, would it be possible to apply the lube without popping out the plunger?
null
Offline saturnotaku
Re: Lubing Topres (HHKB Type-S)
« Reply #1 on: Thu, 30 October 2014, 16:01:19 »
For some people, lubing both the stem and housing has significantly reduced, if not eliminated, the whistling. I suppose you could lube the plunger in situ, but that would probably have minimal, if any, effect.
Offline eth0s
  • Peace & Love
« Reply #2 on: Thu, 30 October 2014, 17:16:46 »
Hmm, if the lube doesn't work, maybe whistle along?  Maybe you can get your HHKB to play a tune?  "Whistle While You Work" would be my choice.  But you can do what you want.
Remember kids:  Walt Disney may have been a Nazi-sympathizer and a virulent anti-semite, but he loved cartoons!   Well, cartoons about white people, that is.
« Last Edit: Thu, 30 October 2014, 17:18:47 by eth0s »
