Author Topic: anyone can help me to identify this keyboard?  (Read 1878 times)
Offline jotillo
« on: Fri, 31 October 2014, 04:39:50 »
Hello, i found this for sale:
http://caseros.olx.com.ar/teclado-antiguo-para-terminal-iid-703851753#galleryContainer
the saller says, it's no label or identification of any kind on the keyboard.
I wonder if it is worth buying it and what type of switches are below those keys?
thank you. greetings from Argentina
« Last Edit: Fri, 31 October 2014, 06:42:53 by jotillo »
Offline trizkut
Re: anyone can help me to identify this keyboard?
« Reply #1 on: Fri, 31 October 2014, 04:56:18 »
All i could find was a geekhack thread from 8 months ago.  Looks to be the same exact pictures:
http://geekhack.org/index.php?topic=54917.0
Offline Oobly
« Reply #2 on: Fri, 31 October 2014, 05:50:31 »
Some type of terminal board, which means it most likely won't work with your PC. No idea of the switches used, you could ask the seller to pull a keycap and send a pic if you really want to find out more.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline jotillo
« Reply #3 on: Fri, 31 October 2014, 06:40:17 »
I have a 122 keys, Model M working with my PC with a Soarer's converter and apparently this keyboard has the same RJ45 plug
Offline CaptLock
« Reply #4 on: Fri, 31 October 2014, 08:21:45 »
dat spacebar    :eek:
« Reply #5 on: Fri, 31 October 2014, 12:38:09 »
it's an SDL connector. All the model Ms that I know of with SDL connectors are PS/2. existance of SDL connector suggests HP. Could be rubberdome.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #6 on: Fri, 31 October 2014, 13:29:47 »
Keycaps look very HP'ish (might be an HP clone?). Might be a dome, but since things look a bit off (and I haven't seen this variant before), probably worth taking a chance.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
