Author Topic: Novatouch LED  (Read 4949 times)
Offline Rainbow_
Novatouch LED
« on: Fri, 31 October 2014, 19:10:35 »
Anyone have any info on adding a caps lock LED to a Novatouch keyboard?
Re: Novatouch LED
« Reply #1 on: Fri, 31 October 2014, 21:40:22 »
I've taken one completely apart: the case is a pain. I recommend getting a nylon stick.
Anyway, there's a place on the PCB for an LED there. There is also a resistor. I would imagine it works if you just solder one in place.
There's also room for scroll lock and winkeylock (F9).
photos:
https://www.flickr.com/photos/dork_vader/sets/72157648601819581/
In retrospect I should have taken better photos.
« Last Edit: Fri, 31 October 2014, 21:42:46 by dorkvader »
Offline Rainbow_
Re: Novatouch LED
« Reply #2 on: Fri, 31 October 2014, 21:43:00 »
Okay, cool, thanks.
Offline frosty
  • jukebox hero
Re: Novatouch LED
« Reply #3 on: Sat, 01 November 2014, 12:07:24 »
Is there mounting holes on the pcb for the leds dorkvader?
Offline Rainbow_
Re: Novatouch LED
« Reply #4 on: Sat, 01 November 2014, 12:36:51 »
There are...
They don't seem to power the LED though
Re: Novatouch LED
« Reply #5 on: Sat, 01 November 2014, 13:06:50 »
There are...
bummer, they must have cut that out of the firmware.
Get a DMM, plug in the KB, turn on capslock and see if you get voltage.
Offline MJ45
  • HHKB Pro
Re: Novatouch LED
« Reply #6 on: Sat, 08 November 2014, 08:45:59 »
There are...
I have seen photos on Deskthority where the smd resistors on the LED circuit were left off the final production boards. The empty spots are near the PCB power header plug.
Offline Rainbow_
Re: Novatouch LED
« Reply #7 on: Sat, 08 November 2014, 18:30:26 »
There are...
[/quote]
Yep, I'm in that thread! Apparently 200ohm works for the LED
Offline feizor
Re: Novatouch LED
« Reply #8 on: Sat, 08 November 2014, 19:03:35 »
There are...
[/quote]
If LED were designed into the PCB already, were they left out for cost saving or is there another reason? Has anyone done the LED mod?
Offline Rainbow_
Re: Novatouch LED
« Reply #9 on: Sat, 08 November 2014, 20:09:47 »
The OP on the thread states that CM/Topre weren't happy with the 3 translucent caps they had.
