Author Topic: Are these UK IBM Model Ms?  (Read 2996 times)
Offline TheSven
« on: Sat, 01 November 2014, 10:15:36 »
First post, yay!
I was reading this http://geekhack.org/index.php?topic=7210.0 and the first 2 links by Roaduck either had none in stock or the website wasn't there. The third (http://partsearch.bluegoosesystems.co.uk/ and search 1391406) did work and seems to be a Model M 1391406 with UK layout. I was wondering if these were also 1391406s or a different Lenovo part.
http://www.chilternitparts.com/productDetail?PartNumber=1391406
http://www.mk-electronic.de/eng/items/show/1391406N
Any help is appreciated, because I would really like to get me a Model M for Christmas.
Re: Are these UK IBM Model Ms?
« Reply #1 on: Sat, 01 November 2014, 10:23:35 »
You did not say whether you were in the UK, but that makes a big difference. If you can spring for more money, ezrahilyer offers some really nice rehab jobs:
http://geekhack.org/index.php?topic=64904.0
When a fool gains power, the first thing he does is silence the wise.
The Next thing he does is gather other fools around him.
The final thing he does is destroy the Nation.
- Plato
Offline TheSven
« Reply #2 on: Sat, 01 November 2014, 10:27:12 »
Yes I am in the UK.
That link says sold though?
« Reply #3 on: Sat, 01 November 2014, 10:27:57 »
Yes I am in the UK.
He will make more.
Offline TheSven
« Reply #4 on: Sat, 01 November 2014, 10:30:54 »
Yes I am in the UK.
He will make more.
UK layout though or nah?
« Reply #5 on: Sat, 01 November 2014, 10:32:49 »
Yes I am in the UK.
He will make more.
That I can't answer, just shoot ezra a PM.
« Reply #6 on: Sat, 01 November 2014, 10:55:48 »
They most likely do refer to the IBM 1391406. Ask the seller before paying (you can have them check the EC number or something. Other keyboards don't have one so you don't care what the number is: just the presence of it. Plus it's a number so you can pretend they are checking so you know it's compatible with your system and they are more likely to do it)
Unfortunately most "spare parts" websites are out of stock on items they say are in stock. You have about a 50-50 chance of them actually having it.
A good place to look for model Ms is a local e-cycler. Check the back side for model number.
Offline TheSven
« Reply #7 on: Mon, 03 November 2014, 09:47:29 »
I sent them an email.
Offline TheSven
« Reply #8 on: Mon, 03 November 2014, 11:01:43 »
Unicomp do a replace service. Would I be able to buy a 1391406 from them?
« Reply #9 on: Mon, 03 November 2014, 11:06:29 »
yeah but it'll cost $arm+$leg for shipping to the UK.
Offline TheSven
« Reply #10 on: Mon, 03 November 2014, 11:09:21 »
It works out to about £103 or $165.
Offline TheSven
« Reply #11 on: Mon, 03 November 2014, 11:56:17 »
Just found UK Unicomp one on thekeyboardco.com which is £8 cheaper, so it's between that and the Bluegoose ones when they come in stock. Bluegoose is a bit cheaper and original IBM not Unicomp so will probably get that.
