Author Topic: Poker 2 question!  (Read 2253 times)
Offline Mesort
Poker 2 question!
« on: Sun, 02 November 2014, 06:40:15 »
Does poker 2 backlit versions have pbt keycaps? I ordered a backlit version from MassDrop. I want PBT keys what can i do :(    (white keyboard-white backlit)
« Last Edit: Sun, 02 November 2014, 07:10:22 by Mesort »
Offline Coreda
Re: Poker 2 question!
« Reply #1 on: Sun, 02 November 2014, 06:44:32 »
Not the ones I've seen.
Offline Mesort
« Reply #2 on: Sun, 02 November 2014, 06:45:34 »
well i ordered a white keyboard with white backlit. So you are saying that its not Pbt?
Offline Roibhilin
  • Saver of Humens
« Reply #3 on: Sun, 02 November 2014, 07:20:04 »
no, they're UV coated ABS afaik
QFR | Poker II | Quickfire TK
Offline itzmeluigi
  • ПБТ
« Reply #4 on: Sun, 02 November 2014, 07:22:20 »
The white LED versions from Massdrop usually have PBT keycaps. The blue and green LED ones are ABS.  It should say on the Massdrop listing if its PBT.
Offline Mesort
« Reply #5 on: Sun, 02 November 2014, 07:31:12 »
 cant find that section : https://www.massdrop.com/buy/kbc-poker-2-clear
Offline Telephasic
« Reply #6 on: Sun, 02 November 2014, 07:34:35 »
Did you order from the drop that just ended o Halloween?
If so, both versions come with PBT.
Back a few pages in the discussion there are a few posts about the backlit versions also having PBT
Offline itzmeluigi
  • ПБТ
« Reply #7 on: Sun, 02 November 2014, 07:36:04 »
Yup those ones are PBT :) Says it in the description.
Offline Mesort
« Reply #8 on: Sun, 02 November 2014, 07:37:06 »
Yea i ordered that is that pbt?
Offline Mesort
« Reply #9 on: Sun, 02 November 2014, 07:37:33 »
Okay guys ty very much ! :p :D ;D :D ;D :D ;D
Offline awhitedev
« Reply #10 on: Sun, 02 November 2014, 07:40:25 »
One thing to add... if you do have one with ABS keycaps you can buy some translucent Vortex PBT keycaps from MK for pretty cheap...
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1008
