Author Topic: Poker 2!!  (Read 1868 times)
Offline Mesort
Poker 2!!
« on: Sun, 02 November 2014, 06:56:35 »
Does poker 2 backlit versions have pbt keycaps?  (white keyboard , white backlit) Just bought one but im not sure its pbt help please. If its not pbt im gonna cancel my order.
Offline awhitedev
Re: Poker 2!!
« Reply #1 on: Sun, 02 November 2014, 07:29:05 »
The backlit ones sold on mechanicalkeyboards.com I believe are all ABS:
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=659
However, I believe the ones sold on MassDrop are PBT:
https://www.massdrop.com/buy/kbc-poker-2-clear?mode=guest_open
Where did you buy your Poker from?
EDIT: You can buy some translucent Vortex PBT keycaps from MK for pretty cheap...
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1008
« Last Edit: Sun, 02 November 2014, 07:30:40 by awhitedev »
