Author Topic: Model M13?  (Read 1216 times)
Offline TheSven
Model M13?
« on: Sun, 02 November 2014, 13:49:21 »
There's an IBM Model M13 (the black one with the track point) on eBay for about $160 (£100). Do you think it's worth it or is it overpriced? Also, is there anyway to hardware reprogram it to be UK layout? Soarer used a Teensy in the terminal keyboards to convert them to usb so I'm wondering if that be as possible also.
Re: Model M13?
« Reply #1 on: Sun, 02 November 2014, 16:08:47 »
That's a bit high.
You can convert it to ISO, though. There's a thread about that on here somewhere.
