Author Topic: How to fix 'gummy' keys on a used Model M?  (Read 2654 times)
Offline Special K
« on: Sun, 12 July 2009, 14:25:44 »
I just got a used Model M today that I bought on ebay.  Overall it's in good shape, but one thing I noticed right away is that some of the keys feel "gummy".  I'm not sure what a more technical term would be.  It's as if the keys are being pressed down into gum.  For example, the right shift key travels smoothly and gives a nice click at the bottom.  The left shift key feels like I'm pressing it down into mud or gum, and doesn't give near as much tactile feedback.  As a result, most of my left Shift presses aren't being registered because I'm not pressing down hard/far enough.
Does anyone know what I'm talking about here?  Is there any way for me to fix it?  I'd rather not have to return this keyboard or complain to the seller because technically all the switches "work", it's just that a few of them feel a little bit gummy and require what seems like an inordinate amount of force to actuate.
« Last Edit: Sun, 12 July 2009, 14:37:52 by Special K »
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
Offline lowpoly
« Reply #1 on: Sun, 12 July 2009, 14:29:28 »
Did you see this thread?
Ebay M with issues, return?
Offline Special K
« Reply #2 on: Sun, 12 July 2009, 14:38:15 »
Quote from: lowpoly;102249
Thanks for the read.  It looks like I'll need to buy a keycap puller now.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline Special K
« Reply #3 on: Sun, 12 July 2009, 14:45:43 »
Quote from: webwit;102255
For an M? I pull those off with my bare hands.
Don't you risk damaging the keys/stems/etc. that way?  I thought that's why people used the key pullers in the first place.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #4 on: Sun, 12 July 2009, 15:09:19 »
On Ms, both keycaps and stems are fairly easily removed by hand. Cherry switches are a different story...
Offline nanu
    • http://T-T.be/portal
« Reply #5 on: Sun, 12 July 2009, 15:16:28 »
Quote from: webwit;102270
If you bend them out to the proper width, how does it properly snap back under the key?
Keys are tapered.
Offline Special K
« Reply #6 on: Sun, 12 July 2009, 15:25:56 »
Quote from: webwit;102261
I don't like that one as you have to fiddle around to separate the ends for each key. Good to remove one key, but will drive you crazy if you have to remove all keys with it.
You're saying the one sold by Hoolean is better than the one sold by Majestouch?
EDIT:
Hoolean: http://hooleon.com/miva/merchant.mvc?Screen=PROD&Product_Code=AC-999-0039&Category_Code=KT-P&Product_Count=2
Majestouch: http://www.elitekeyboards.com/products.php?sub=access,keycaps&pid=fkb118
I'm just making sure I am comparing the right products.
So the one from Hoolean is $14.85 after shipping, but the one from Majestouch is only $6.50 after shipping.  Is the one from Hoolean worth $8.35 more than the one from Majestouch?
$6.50 seems like a really good deal, but if the Majestouch keycap puller doesn't work correctly, then I guess I shouldn't buy it.  Otherwise it seems like a great deal, especially since he doesn't seem to rip you off on shipping for such a small item, as many other online stores do.
« Last Edit: Sun, 12 July 2009, 15:39:20 by Special K »
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline ch_123
« Reply #7 on: Sun, 12 July 2009, 19:17:19 »
I hear fingers and flat-head screwdrivers are pretty cheap these days...
Offline Manyak
« Reply #8 on: Sun, 12 July 2009, 20:09:34 »
Just to drive the point in, you really don't need one for an M.
The whole point of using them is so you don't damage the switches underneath by pulling the plastic stem out. But the model M caps aren't attached to anything. Just pry them out with a screwdriver.
Currently Owned:
Filco FKBN104MC/EB - Model M 1390131 \'86 - Model M 1391401 NIB - Unicomp Endurapro NIB - iRocks KR-6230 - Compaq MX-11800 - Cherry G80-8113HRBUS-2 - Cherry ML-4100 - Cherry MY-8000-something - Dell AT101W (Black) - ABS M1 - Siig Minitouch - Chicony KB-5181 w/ SMK Montereys - Chicony KB-5181 w/ SMK Montereys NIB - Cherry G80-3494LYCUS-2 - Deck Legend
Offline Special K
« Reply #9 on: Sun, 12 July 2009, 20:47:43 »
Quote from: webwit;102278
I dunno. But you really don't need one for an M.
Wow, you weren't kidding.  Both keycaps popped right off using only my fingers.  Now that I look at the area underneath the keys, I can see this thing needs a good cleaning.
How do I get the screws out that hold the casing together?  My multi-tip screwdriver can't reach down into that narrow of a hole.
« Last Edit: Sun, 12 July 2009, 21:26:48 by Special K »
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
