Author Topic: Green Alps Clone?  (Read 3919 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Green Alps Clone?
« on: Sun, 02 November 2014, 16:17:25 »
Looks like a cloner to me?
Never heard of Yachi (last picture) before? Has KB 6251 in the second picture?
Not that big of a deal for a board, but it did clean up fairly well. Had to fill in missing keycaps with some odds and ends I had on the shelf........
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Green Alps Clone?
« Reply #1 on: Sun, 02 November 2014, 16:54:34 »
It's a Nan Tan KB-6251 or KB-6252 (the model number on the case does not always match the PCB):
http://deskthority.net/wiki/NTC_KB-6251
If you look on that page, there's a "6752" with green Alps clones. I think the "7" is a mistake personally. Most of us have V5, which has "2".
The switches are most likely to be linear. It would be interesting to see inside one of them to see what internals they use. I've never seen the numbering on the other one, but on yours I can.
What's the date on the controller chip? (In YYWW format hopefully.) Mine seems to be 9031, making it 1990, although mine has genuine Alps switches.
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Sun, 02 November 2014, 18:17:01 »
----- Will pop it apart tomorrow and grab the date and picture for you
I did not know this went through....... I kept getting errors and had given up on it (the thread) :-\
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Mon, 03 November 2014, 12:30:19 »
is this what you are talking about?
  • RIP
    • Boring twaddle
« Reply #4 on: Mon, 03 November 2014, 12:35:13 »
That's the one. 1993 week 5 then … Interesting. I need to get 002 to check the date on his SIIG MiniTouch, as that appeared to be made at the time that those style switches (with the simple numbers) were being replaced with the new numbering.
Bore Awards
Offline Muzi
« Reply #5 on: Mon, 03 November 2014, 17:43:35 »
nice keyboard
  • RIP
    • Boring twaddle
« Reply #6 on: Mon, 03 November 2014, 17:46:39 »
It's not bad. It's got a plastic plate, so it's lightweight, but it's still better than modern office keyboards. If only NTC had made one with Windows keys and proper ISO enter and 2 u backspace.
Bore Awards
Offline jacobolus
« Reply #7 on: Mon, 03 November 2014, 19:28:09 »
If someone has one of these they want to unload (for cheap-ish), or even a handful of loose switches, hook me up!
http://geekhack.org/index.php?topic=64803
