Author Topic: Another AT Model F, $30  (Read 4497 times)
Offline Manyak
Currently Owned:
Filco FKBN104MC/EB - Model M 1390131 \'86 - Model M 1391401 NIB - Unicomp Endurapro NIB - iRocks KR-6230 - Compaq MX-11800 - Cherry G80-8113HRBUS-2 - Cherry ML-4100 - Cherry MY-8000-something - Dell AT101W (Black) - ABS M1 - Siig Minitouch - Chicony KB-5181 w/ SMK Montereys - Chicony KB-5181 w/ SMK Montereys NIB - Cherry G80-3494LYCUS-2 - Deck Legend
Offline Hak Foo
  • Make America Clicky Again!
« Reply #1 on: Mon, 13 July 2009, 01:23:42 »
NOT an AT F.  It's clearly an XT by the layout and lack of lamps.
I wonder if putting an AT-> PS/2 adaptor on such a board would work on a PS/2 model 25 or 30 (analogous to an XT)
Overton130, Box Pale Blues.
Offline Manyak
« Reply #2 on: Mon, 13 July 2009, 01:55:33 »
oopsies!
I hope whoever bought it has an XT->AT adapter.
Currently Owned:
Offline ch_123
« Reply #3 on: Tue, 14 July 2009, 12:05:57 »
Quote from: Hak Foo;102332
I've never heard of an XT keyboard with a PS/2 connector... I'm pretty sure those PS/2s probably used the AT scancodes, even if their basic spec was similar to the original PC/XT.
Offline Manyak
« Reply #4 on: Tue, 14 July 2009, 12:20:40 »
Quote from: ch_123;102539
It's not just the scancode that differs, it's the entire protocol. Everything from the number of bits per packet to the timing of data line reads (AT reads on clock high, XT reads on clock low....or the other way around but they are still opposite).
Currently Owned:
Offline timw4mail
    • https://timshomepage.net
« Reply #5 on: Tue, 14 July 2009, 12:58:40 »
Quote from: Manyak;102540
Which the conversion, no doubt adds a few milliseconds to the key response time. Anyone use an XT with an adapter?
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline ch_123
« Reply #6 on: Tue, 14 July 2009, 13:22:52 »
Yeah... I meant that but was too lazy to spell it out in it's entirety :p I stand by my point though - I think IBM made those 8088-equipped PS/2s with the modern AT protocol - I'm pretty sure those LED-less Model Ms were AT compatible.
Offline Manyak
« Reply #7 on: Wed, 15 July 2009, 20:13:38 »
Quote from: ch_123;102543
The LED-less Model Ms (1390120) were AT, I don't think the M was ever made XT.
Currently Owned:
Offline ch_123
« Reply #8 on: Wed, 15 July 2009, 20:15:36 »
Well there you go, plugging an XT into a PS/2 will not work, even if the spec is otherwise similar to that of a PC or PC/XT
Offline Mercen_505
« Reply #9 on: Wed, 15 July 2009, 20:31:41 »
Build-wise, there is a pretty huge difference between the XT and AT model F keyboards. Now that I have both, I can see that the AT board is pretty shoddy in comparison. I guess I need to take some pics to properly explain it, but although the layout sucks, I prefer the XT's superior build quality. I'm typing this up on my AT model F now... at least it works!
Offline ch_123
« Reply #10 on: Wed, 15 July 2009, 20:52:18 »
The idea that there's something even more over-built than the AT Model F is somewhat frightening to be hoenst :P. That said, when I saw some youtube videos of the original IBM PC, I noticed how the keyboard made a much more satisfying snap than that of my AT Model F. I wonder how the Model F terminal boards were in comparison...
Offline Mercen_505
« Reply #11 on: Thu, 16 July 2009, 12:23:31 »
The model F XT I have is like a freaking brick -- rock solid and there is absolutely no flex to the board whatsoever. The keys sit neatly centered in the openings on the top of the frame, and don't have much 'wobble' to them (take a key and try to turn it like a knob) except for the double height keys on the right side... which wobble like crazy.
The Model F AT I got recently is of significantly cheaper build. The board itself has a little flex to it, and it has cheap (and small!) rubber nubs on the bottom to hold it in place. The keys are off center, tend to wobble in their seatings, and there is a lot of flash on the top of the case, especially in the tabs that go between the spacebar and the caps lock/alt keys. The casing seems to be a gray material that has a cream colored coat on it, and excessive wear eventually reveals this. What I thought was a dirty spot was actually the gray color showing through! Whoops :(
There is always the possibility that I got a shoddy piece. As it stands I'm pretty disappointed with it compared to my (admittedly useless) XT board.
Offline timw4mail
« Reply #12 on: Thu, 16 July 2009, 12:25:43 »
Quote from: Mercen_505;102890
Does the Model M still seem cheap in comparison to the Model F?
Offline Mercen_505
« Reply #13 on: Thu, 16 July 2009, 13:03:20 »
Depends. I've got several silver label Ms that are of excellent quality; certainly the only thing they lack compared to an F (XT) is weight! I also have a few blue label Ms that are... not nearly as nice.
Offline Mercen_505
« Reply #14 on: Thu, 16 July 2009, 13:45:08 »
Dunno. Having worked for several equipment manufacturers over the years, I can safely say "Things change." Build quality can fluctuate significantly over time based on availability of materials, changing specs in a subtle way to save money or suit customer needs, or at the whim of a penny-pinching purchasing agent. It wasn't unusual to experiment with alternative parts for a few months, then return to the old stuff when things didn't work out as planned, or the pricing changed.
Offline Mercen_505
« Reply #15 on: Thu, 16 July 2009, 13:58:09 »
I really need to have a micrometer but early results indicate this whole Blue Label/Black Label thing is bogus. The Unicomp on the other hand....
Measurement of plastic isn't exactly enough. The composition of the plastic is also important, and likely to change over time. My two silver labels are a 1390120, and 1390131. My two blues are 1391401s.
Offline Mercen_505
« Reply #16 on: Thu, 16 July 2009, 14:00:10 »
I take that back. One blue is a 401, the other is something else -- I think.
Offline Mercen_505
« Reply #17 on: Thu, 16 July 2009, 14:15:27 »
I can give you a full inventory when I get home. I know I have one IBM made blue, and one Lexmark blue... two IBM silvers... a lexmark m4, a unicomp m4, three M2s, and some other odds and ends (industrial, model F, yadda yadda)
I need to take some pics, but my camera is a bit on the ****e side.
Offline Manyak
« Reply #18 on: Thu, 16 July 2009, 18:06:39 »
If it's any help I've got a Silver/Black 301, Blue 401, and Black NIB 401. All IBMs.
There's really nothing remarkably different about any of them other than the 301 having stiffer keys and thicker, rounder lettering. And it feels a bit heavier than the other two, though the sturdiness is about the same.
But between the two 401's the only difference that stands out is the key feel, but I'm almost positive it's because one is used and the other is still brand new.
« Last Edit: Thu, 16 July 2009, 18:31:09 by Manyak »
Currently Owned:
Offline Mercen_505
« Reply #19 on: Thu, 16 July 2009, 18:47:50 »
Whee... I'm taking inventory right now. I've got just over 100 pictures to sort and crop, showing various angles of all my boards as well as the labels on the back and any noteworthy attributes. I'll try to go through some of them at work tomorrow; I know I won't finish up tonight!
None of my boards are NIB, but I have several that are barely used.
Offline timw4mail
« Reply #20 on: Thu, 16 July 2009, 18:49:24 »
Quote from: Manyak;102966
I only have one Model M, but does your Model M have kind of a "muffled" click compared to the Model F? (I'm not really asking you, Manyak :rolleyes:)
Offline timw4mail
« Reply #21 on: Fri, 17 July 2009, 13:57:22 »
Quote from: ripster;103054
OK, I opened up the whole Black/Grey/Blue Model M debate here.
If somebody is willing to open up let's say a late 80's vintage Model M we can nail this down once and for all.  Grab a scale and a Vernier/Micrometer if you have one.
I have one, but I'm not too willing to open it at this point. I also don't have the tools...
Offline Manyak
« Reply #22 on: Fri, 17 July 2009, 14:30:32 »
I'd do it but I don't have a scale or micrometer.
Currently Owned:
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #23 on: Sat, 18 July 2009, 08:12:19 »
I've opened my blue M up a few times but I don't have any other M's to compare it to.
« Reply #24 on: Sat, 18 July 2009, 13:07:45 »
Well, any model M will get the job done fine. Personally, if I was to buy another, I'd get a blue-label one because it's $40 cheaper just to have your keyboard dry out more easily when something spills on it.
Offline Mercen_505
« Reply #25 on: Sat, 18 July 2009, 14:25:01 »
Sorry; been busy today. But that's okay, my 1391 is on loan to my father, and I'll be getting it back next weekend. Then I can start some proper testing, whatever that turns out to be ;)
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #26 on: Sat, 18 July 2009, 16:25:21 »
None of my UK-made Ms seem to have ABS cases. At least my 1991 sample had a yellowed space bar and logo but the case looks unimpressed. So PVC it is then. Good to know.
Speaking of materials, Czech-made Cherry keycaps actually say PBT underneath.
Offline ch_123
« Reply #27 on: Wed, 29 July 2009, 20:09:59 »
Quote from: ripster;105386
Polycarbonate/ABS mix.
I'm going to go change Wikipedia Model M entry to read,
"A classic board except for Greenock UK units.  IBM engaged in dumping carcinogenic cheap plastic versions.  Coverup in progress - see Google Earth image".
Was your M4 made in Greenock?
