Author Topic: Asian OEM profile PBT keycaps with similar feel to Realforce keycaps?  (Read 3536 times)
Offline Veridis
Hello everyone, I'm really liking the pbt keycaps on the Realforce 87u. Are there any MX keycaps in CM/Filco/Ducky/etc OEM profile pbt keycaps that are similar to the topre ones?
Ducky Shine 3 TKL (MX Brown) | CM Rapid-i (MX Brown) | Realforce 87u 45g Uniform | CM Novatouch | Ducky Zero TKL (MX Brown) | Das Keyboard III (MX Blue)
Re: Asian OEM profile PBT keycaps with similar feel to Realforce keycaps?
« Reply #1 on: Mon, 03 November 2014, 00:47:59 »
GMK PBT are fairly close.
« Reply #2 on: Mon, 03 November 2014, 01:19:26 »
GMK does pbt?
« Reply #4 on: Mon, 03 November 2014, 04:50:37 »
GMK does pbt?
Er, these PBT keycaps from Ivan's GB I am using now.  Dyesub.  Not GMK?
« Reply #5 on: Mon, 03 November 2014, 07:53:13 »
GMK does pbt?
The black ones are PLUM, the others are KBC I think.
Offline Veridis
« Reply #6 on: Mon, 03 November 2014, 22:04:28 »
Anyone tried Vortex PBTs? How do they feel?
Offline jameslr
« Reply #7 on: Tue, 04 November 2014, 15:14:29 »
BSP is probably the highest quality you can find but it is very expensive. I can recommend Leopold PBT caps as they're pretty cheap for the quality.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline Veridis
« Reply #8 on: Tue, 04 November 2014, 18:31:43 »
I've bought a set of the cherry profile like Leopolds, but they clack a lot on stabilized keys due to low clearance on the Novatouch , so I am staying away from low profile keys as of now :(
