Author Topic: Got new Leopold PBT caps and I do not know how to make the modifiers not wobbley  (Read 2783 times)
Offline connorelsea
  • Java programming and fancy key caps!
    • Elsea Labs
Got new Leopold PBT caps and I do not know how to make the modifiers not wobbley.You can see in the pictures below what I am talking about.
« Last Edit: Mon, 03 November 2014, 11:48:17 by connorelsea »
Elsea Keys - Artisan key caps, keyboards, custom painting - Click any image to purchase or view
Offline oscillik
    • music podcasts
you're missing the stabilizer stems
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Are you using your stabilizer inserts?
Offline connorelsea
    • Elsea Labs
WASD provided stabilizers when I bought the bare-bones keyboard, but I am not exactly sure what they are or how I use/insert them.
1) Take little white stabilizer inserts in hand
2) Face the longer side towards escape
3) Push into the holes in the bottom of the keycaps
4) Catch the wire into the insert holes
5) Push spacebar into keyboard
Offline dante
This video helped me out a lot when I first encounted costar stabilizers:
Offline ConscienceDrop
  • a-are these pbt?
i dont think you should be torquing a switch like you are with that space bar in OP pic . . .
also what people above have been saying, you are missing the stabilizer inserts. your old space bar might still have them inside them so go get that and flip it over and check.
