Author Topic: Where to buy individual keys, not full sets  (Read 4567 times)
Offline tchap
« on: Mon, 03 November 2014, 17:43:11 »
I want to find around 50 unmarked keys for a special project, and all keys are the same type keycap.  I am using cherry mx.  I found some clear keycaps that are not marked.  I want types that will fit next to each other and look identical.  Can anyone suggest a source for a keycap that I can buy that is the same type?  Much appreciated.
Re: Where to buy individual keys, not full sets
« Reply #1 on: Mon, 03 November 2014, 18:17:55 »
Welcome to Geekhack!
Do you want DSA profile?  They all look identical, and definitely sit next to each other, regardless of what row they are.
http://keyshop.pimpmykeyboard.com/products/full-keysets/dsa-blank-sets-1
http://keyshop.pimpmykeyboard.com/products/full-keysets/dsa-extra-blank-keys
Depending on how many you want, PMK sell individual keycaps for about $1 each, or, say, a numpad set (18 keycaps) for $11.
Offline tchap
« Reply #2 on: Mon, 03 November 2014, 18:32:34 »
Thanks for the info on DSA.  Yes  that looks fine.  This is not a keyboard, it is a bank of buttons for a special system so I like the same style.  I wonder if there is a better looking version of that same style.
Offline tchap
« Reply #3 on: Mon, 03 November 2014, 18:47:41 »
http://keyshop.pimpmykeyboard.com/products/full-keysets/full-clear-translucent-dcs-keycap-sets
Is this DCS similar in terms of each key being identical?  I like this look.
Offline inlikeflynn
  • file not found
« Reply #4 on: Mon, 03 November 2014, 18:55:45 »
most of the rows will have a different profile from the others, so they wouldn't be identical and probably wouldn't look good if all in a line 50 across or something.
I'd suggest Relegendable keycaps as you could keep the profile the same and have a clear top in case wish to label them in the future
http://www.keycapsdirect.com/faq.php#13
you can buy the 50 or so from there too (FYI pimpmykeyboard is the same company, Signature Plastics)
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline tchap
« Reply #5 on: Mon, 03 November 2014, 19:41:04 »
http://www.keycapsdirect.com/images/Ruby/Completeset.jpg
I like these Ruby key the best from that link you posted.  These look like money.  Now to find out how I can pipe some RGB light up into it.
« Last Edit: Mon, 03 November 2014, 19:45:21 by tchap »
« Reply #6 on: Mon, 03 November 2014, 21:30:05 »
The red ones?  They are standard DSA - not transparent.
DSA keycaps are also usually fairly thick, so you'd need very bright LEDs to make those light up.
