Author Topic: Is it possible to make a keyboards repeat rate overlap multiple keys?  (Read 1295 times)
Offline Cqxdwm
I've discovered that you can increase the keyboard repeat rate beyond OS restrictions. I'm looking for a similar way make the keys continue to repeat even if you press down other keys?
Example: you hold down a and it starts repeating and if you tap any other key, the repeating stops. It's the cancellation that i want to get rid of.
Is it doable without running 3rd party programs?
Offline Data
Re: Is it possible to make a keyboards repeat rate overlap multiple keys?
« Reply #1 on: Thu, 06 November 2014, 09:03:35 »
I don't think that's possible because of the way keyboards use changes in voltage to signal a key press, based on my very limited knowledge.  Dorkvader could probably give you a much more technical answer.  It may depend on the firmware and/or controller.
