Author Topic: Unpopular Keyboard Opinions  (Read 2542345 times)
0 Members and 6 Guests are viewing this topic.
Offline zombimuncha
Re: Unpopular Keyboard Opinions
« Reply #3100 on: Sun, 28 August 2016, 15:17:28 »
Topre is way over-hyped.
After reading all the praise, I bought an 87U 55g and all I can say is meh...
Try a HHKB. Much nicer. I went from 87u 55g to HHKBT, and I don't use the 55g anymore.
I also do not care for the HHKB layout......but they do look nifty.
The layout takes about a week to get used to, but once you get used to it you can never go back to other layouts. I have all of my boards with Control and Caps switched, and if I can I get them all with the diamond arrows too. Such a nice layout once you give it a try
I tried the layout for a day, until I found that to do a sequence like Ctrl-C, Ctrl-Shift-F, Crtl-V I would have to change which finger I pushed Ctrl with in the middle of the sequence. That's when I noped out of the swapped Ctrl-Caps scene.
I don't understand?
C, F, and V are all right next to eachother.
You should just be able to hold control with your pinky and press all three
It starts out fine with the pinky on Ctrl for Ctrl-C, but then for Ctrl-Shift-F I have to move my pinky down to Shift and hit Ctrl with my ring finger.
Offline clankgy1
  • Formerly digifiend
« Reply #3101 on: Tue, 30 August 2016, 00:26:45 »
Demik was nice enough to let me borrow his lubed and silenced HHKB for a test drive as I considered having the same work done on mine.
I HATE LUBED AND SILENCED HHKBs.  Not a popular opinion, but I found the lubed/silenced HHKB lacked the very noise characteristics I like about the HHKB, the keys felt mushy, and the reduced key travel was noticeable.  My suggestion would be to try such a board before inflicting this kind of mod on it unless you enjoy the prospect of eternal disappointment.
RF87U 55g (damaged)  |  AV3 w/POM Plate  |  Thermal (to be built)  |  ID80v1 (to be rebuilt)  |  Tokyo60
Offline Giorgio
« Reply #3102 on: Tue, 30 August 2016, 05:41:39 »
silenced with hypershpere washers or with landing pads?
landing pads are way thicker
Offline clankgy1
« Reply #3103 on: Tue, 30 August 2016, 15:39:54 »
No idea on specifics of mods.  I didnt' care for it, and am thankful my HHKB has full thock. :)
Offline Niomosy
« Reply #3104 on: Tue, 30 August 2016, 16:23:51 »
Untrue.  I had Sun keyboards that I used for my primary job which were in the HHKB layout.  I gleefully went back to a standard ANSI board after months straight on what is the HHKB layout.  As a layout designed to work with UNIX and vi, I found it worse than ANSI for those specific purposes.
Also, the HHKB lacks a lot of things like arrow keys and function keys not on a second layer - less ergonomic for me as the Fn Num combinations create more pain than simply moving my hand a little bit further up to hit that function key.
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #3105 on: Tue, 30 August 2016, 23:04:45 »
Have you ever tried the Space-Fn concept? If you have not, it is advisable to try it and to see if you can use it, if so maybe a sixty layout is for you; otherwise you should go with Fox or FC-660 similar layouts.
Im not really familiar with the Space-FN concept, im not too fond with having too many fn layers too. Yeah im opting for something like a 66key or 68key. I guess i wont miss the Function keys too much compared to the dedicated arrows.
My preference is for a 60 or 65% keyboard.  I do like dedicated arrow keys, but it's nice when they are included on the home row and you don't have to move your hand or look at your board to access them.  You could also get a 60% board and have a separate numberpad including arrow keys and have the best of both worlds.
I was looking at cheaper 66-68-keys that doesnt look like va68 or fc660 or MF 68.
I prefer the layout of WF, RS, TADA? maybe? hehe i guess ill have to wait for more reviews.
the separate numpad is a no go for me i want 1 single keyboard for my needs  :thumb:
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #3106 on: Fri, 23 September 2016, 14:35:40 »
I like full size keyboards
Offline alienman82
« Reply #3107 on: Fri, 23 September 2016, 14:45:53 »
removed.
« Last Edit: Thu, 01 March 2018, 14:09:02 by alienman82 »
Offline sncbraxsc2
« Reply #3108 on: Fri, 23 September 2016, 15:02:45 »
due 101% is best size
Is that like an AEK style? I've never heard of 101% :P Or do you mean like 101 key style? I would agree with that, I love wkl layout
Offline alienman82
« Reply #3109 on: Fri, 23 September 2016, 15:07:13 »
removed.
« Last Edit: Thu, 01 March 2018, 14:08:58 by alienman82 »
Offline captsis
  • Formerly matt2dlg
« Reply #3110 on: Sun, 25 September 2016, 01:05:55 »
Razer keyboards arent that bad if you get one for cheap
Sent from my SM-G920V using Tapatalk
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #3111 on: Sun, 25 September 2016, 05:08:53 »
Nah id rather be spending my small amount of cash on something else tho.  :p
Offline keyladding
« Reply #3112 on: Mon, 26 September 2016, 09:06:17 »
Razer keyboards aren't that bad if you pay a lot for it.
Offline y11971alex
  • Looking for Toronto meetup
« Reply #3113 on: Mon, 26 September 2016, 18:58:53 »
IBM rubber domes are better than Cherry MX Browns
Offline mike52787
  • Alps Aficionado
« Reply #3114 on: Mon, 26 September 2016, 18:59:37 »
anything is better than mx browns
Offline Niomosy
« Reply #3115 on: Mon, 26 September 2016, 20:43:21 »
MX blues for starters.  I'd rather be on rubber domes.  Though, to be fair to blues, I haven't tried greens yet which are everything I don't like about blues, but with the added weight I also don't like.
Offline mike52787
  • Alps Aficionado
« Reply #3116 on: Mon, 26 September 2016, 20:45:12 »
True. Anything is better than cherry switches with the exception of clears.  I would rather type on a scissor switch or a good quality rubberdome.
Offline Niomosy
« Reply #3117 on: Mon, 26 September 2016, 20:49:07 »
At the moment, my favorite switches are MX reds.  Would love to try out some hall effect switches if they ever manage to get them into production.  Haven't tried Topre, though I'm more a linear switch fan.
Offline mike52787
  • Alps Aficionado
« Reply #3118 on: Mon, 26 September 2016, 20:50:24 »
Try alps SKCL green and never use mx reds again
Offline Niomosy
« Reply #3119 on: Mon, 26 September 2016, 23:05:13 »
Need some MX sliders or something there so I can us my MX compatible caps.  Really want to try Gateron reds and yellows to be honest.
Offline E3E
« Reply #3120 on: Tue, 27 September 2016, 21:53:36 »
Is this an opinion?
Offline pixelpusher
« Reply #3121 on: Fri, 30 September 2016, 09:14:56 »
Matias Clicky feels like I pulled the board out of a dumpster... and it's perfect... it is endgame.  Yet I still try others because what the hell else is there to do in life.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #3122 on: Fri, 30 September 2016, 09:16:02 »
I liked my matias quiet clicks more than all the old / vintage alps switches I tried
Offline Fictiouz
  • That "White" Guy
« Reply #3123 on: Fri, 30 September 2016, 09:18:26 »
You also like MX Reds more than the sweet feel of cup rubber ;)
Offline Moistgun
  • Slippery When Wet
« Reply #3124 on: Fri, 30 September 2016, 09:20:31 »
I prefer hydro over another keyboard. :P
Offline mike52787
  • Alps Aficionado
« Reply #3125 on: Fri, 30 September 2016, 15:10:42 »
*pukes*
Offline alienman82
« Reply #3126 on: Fri, 30 September 2016, 17:11:11 »
removed.
« Last Edit: Thu, 01 March 2018, 14:07:27 by alienman82 »
Offline davkol
  •  Post Editing Timeout
« Reply #3127 on: Sat, 01 October 2016, 12:15:36 »
I've never tried matias, but I can't imagine them being very good compared to real SKCM
Not even wrong…
Offline Tesyu
« Reply #3128 on: Mon, 03 October 2016, 12:51:47 »
I agree with your opinion on HHKB and topre.
But I think 60% and arrow keys are compatible,such as XD60,Pure pro.
Offline Vagabond
« Reply #3129 on: Mon, 03 October 2016, 13:26:04 »
eBay artisans are fairly priced
Offline alienman82
« Reply #3130 on: Mon, 03 October 2016, 13:33:25 »
removed.
« Last Edit: Thu, 01 March 2018, 14:03:22 by alienman82 »
Offline zacheadams
« Reply #3131 on: Mon, 03 October 2016, 19:45:54 »
I just wish there were more listings.
Offline jonathanyu
« Reply #3132 on: Wed, 05 October 2016, 02:13:19 »
keyboard is just keyboard
$5 rubberdome is enough
Offline mushman
« Reply #3133 on: Sun, 09 October 2016, 17:00:20 »
Agreed.  Wish they made a tenkeyless K120 or DT35.
Offline kittenpolice
  • mods are asleep, post logitech
« Reply #3134 on: Tue, 11 October 2016, 21:27:00 »
Does the fact that the stems / top of the switches are exposed here have a name? Whatever this phenomenon is called, I hate it and am bothered by keyboards that have it.
Offline mushman
« Reply #3135 on: Tue, 11 October 2016, 21:42:00 »
It's referred to as "floating keys design" or "viki style" in South Korea.
Offline ideus
  • Björkö.
« Reply #3136 on: Tue, 11 October 2016, 21:45:40 »
I have read names like Floating-key design
Ups! someone already posted the same, :thumb:
Offline eksuen
  • Ambassador of explosions.
« Reply #3137 on: Tue, 11 October 2016, 23:37:57 »
I don't like it either. I think it changes aesthetics and the sound of typing for the worse.
Offline E3E
« Reply #3138 on: Tue, 11 October 2016, 23:51:26 »
I think floating key designs can be nice in some cases, but I too prefer high profile cases. As stated, they have better acoustics and eliminate that "naked," incomplete look that some of these floating-key boards can have.
« Reply #3139 on: Fri, 14 October 2016, 09:06:46 »
Ah thank you for telling me.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3140 on: Fri, 14 October 2016, 09:13:36 »
I've read blog posts and forum posts that describe it as a 'low profile case' (floating key). afaik there is no 'high profile case', just a regular profile and low profile.
Offline E3E
« Reply #3141 on: Fri, 14 October 2016, 09:30:21 »
I think that's all relative to current trends and standards though. Low profile in the 1970s was not low profile in the 1980s, and the vintage boards of the 1980s are certainly not considered low-profile today.
Relative to the floating key look, you can consider cases with walls that conceal the switches to be high profile, and it's a good and easy way to make the distinction especially if the majority of aftermarket cases for a particular layout happen to be low profile, like with 60% keyboards.
Offline mike52787
  • Alps Aficionado
« Reply #3142 on: Fri, 14 October 2016, 09:45:20 »
I too hate low profile 60% cases, but high profile aluminium 60% cases are sooo expensive. The 15$ plastic ones from china rent too bad though.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3143 on: Fri, 14 October 2016, 09:54:59 »
Sorry, yea you're totally right. I was thinking along the lines of modern keyboard design rather than the full gauntlet of keyboard case height profiles.
Offline blackriver
  • One of the Cookie Kids
    • Desk Cookies
« Reply #3144 on: Fri, 14 October 2016, 22:33:47 »
1. RGB is so overhyped, it looks like garbage if you use more than like 3 colors and costs an arm and a leg.
2. After testing any mechanical keyboard ever, I regret having ever typed on a Razer.
3. Alps switches are ******g sick!
4. Keytronic rubber domes actually don't feel half bad.
9x HHKB's, Astro Norbaforce, Coffee Heavy Grail, Silver Digilog, FMJ 60, 2x HB60's
Offline alienman82
« Reply #3145 on: Fri, 14 October 2016, 22:54:59 »
removed.
« Last Edit: Thu, 01 March 2018, 13:56:51 by alienman82 »
Offline mike52787
  • Alps Aficionado
« Reply #3146 on: Fri, 14 October 2016, 22:56:06 »
maybe not #3
maybe yes #3
Offline fublamchu
  • ㅋㅋㅋ
« Reply #3147 on: Fri, 14 October 2016, 23:15:08 »
maybe not #3
are any of these particularly unpopular? (not quite sure about #4)
LZ-CE VBlacks
910-CE
« Reply #3148 on: Fri, 14 October 2016, 23:15:52 »
maybe not #3
Classic Alps>>>>>>>MX>>Matias Alps
Offline alienman82
« Reply #3149 on: Sat, 15 October 2016, 00:26:39 »
removed.
« Last Edit: Thu, 01 March 2018, 13:56:46 by alienman82 »
