Author Topic: Phantom PCB in a Quickfire case?  (Read 1790 times)
Offline mathiasx
    • My Blog
« on: Fri, 07 November 2014, 12:29:50 »
I'd like to build a Teensy 2.0-based TKL-style keyboard as a gift for someone. My thought was to start with the Phantom PCB and build it up, but I need a case for it.
I know the Phantom is meant to fit Filco Majestouch-style case, and I know that some people have used Quickfire cases with the Filcos by modding some of the screw locations and the cutout for the cable to pass through.
Has anyone built a Phantom PCB into a Quickfire case? It seems like it should be way easier to get a Quickfire case than a Filco Majestouch.
Thoughts?
Offline frosty
  • jukebox hero
Re: Phantom PCB in a Quickfire case?
« Reply #1 on: Fri, 07 November 2014, 12:41:07 »
Yes, just modify it.
