Author Topic: Looking for a backlight compatible dolch set, anyone know if it exists?  (Read 2485 times)
Offline gamerfry
I've been looking for a backlight compatible dolch set for about a week now to use with my ducky shine 3 tkl with white LED's with absolutely no luck. I thought I'd ask around here before I ordered a grey set of ducky keys to go with the default black and just consider that close enough. Please let me know!  :D
Offline bazemk1979
Re: Looking for a backlight compatible dolch set, anyone know if it exists?
« Reply #1 on: Sat, 08 November 2014, 11:21:45 »
closest that you can get and having double shots 2 tone keycaps made out of thick pbt material which means they will never fade off unlike all the standard backlit caps that they come with all the keyboards, your best 2 tone option effect is by buying the Vortex backlit PBT DS caps, buy the white and black set so you can get the 2 tone feeling when u mix them up. I like the Vortex legends on their DS sets.
Little more about the sets can be found here http://geekhack.org/index.php?topic=61149.0
Offline Oobly
« Reply #2 on: Mon, 10 November 2014, 01:24:00 »
Closest you'll get in terms of looks is probably the grey and black Ducky sets.
This is what GMK Dolch looks like with white backlighting:
81564-0
I like it, but I'm not a big fan of backlighting in general, so I don't often turn it on. Mostly just for looking at now and then :) I prefer to always have enough general light to be able to see the legends, better for your eyes that way.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
