Author Topic: De-solder switches from keyboard  (Read 1314 times)
Offline Linuus
« on: Sat, 08 November 2014, 07:00:47 »
Hi
I'm about to build an ergodox keyboard but I have trouble finding any Brown or Blue switches for it in Sweden. So, I thought I'd just buy a keyboard with those switches and rip it a part. Something like the CM Storm QuickFire TK.
Will that work?
Are the switches on those keyboards PCB or plate mounted?
Offline jameslr
Re: De-solder switches from keyboard
« Reply #1 on: Sat, 08 November 2014, 08:22:47 »
Yes and they are plate mount. You can buy switches from mouser.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline BlueBär
« Reply #2 on: Mon, 10 November 2014, 04:06:35 »
Shipping rates from the US + customs fee make it usually not worth it.
Offline jameslr
« Reply #3 on: Mon, 10 November 2014, 16:57:25 »
Mouser has a German store front. http://mouser.de
Offline jameslr
« Reply #4 on: Mon, 10 November 2014, 16:59:46 »
They have a Swedish store front too. I think their EU sites ship from EU not USA.
Offline BlueBär
« Reply #5 on: Mon, 10 November 2014, 17:05:26 »
Price per switch at 100 switches: 0,80€. That's about a dollar per switch. Shipping costs are expensive as well.
You can get cheaper switches in Europe from 7bit.
