Author Topic: PLS HELP  (Read 4768 times)
Offline Dr.Chipotle
PLS HELP
« on: Sat, 08 November 2014, 13:20:00 »
So i decided switch the green razer switches from my blackwidow with cherry mx browns, but decided to only put in 5 just to see how they would feel. When i was typing 10 keys didnt work(ones that were not replaced and kept the same) they keys are 7,+/=, backspace, U,I,O,PD, {/[, and left shift, anyone knows why those keys dotn work and im typing this with an old membrane keyboard
Offline Oobly
Re: PLS HELP
« Reply #1 on: Mon, 10 November 2014, 01:55:52 »
Sounds like a bad soldering job. Which keys did you replace?
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Pemdas
Re: PLS HELP
« Reply #2 on: Mon, 10 November 2014, 05:01:48 »
If you can you should add some pictures of the solder points and the switches you replaced. Would be easier to identify the problem.
Offline Dr.Chipotle
Re: PLS HELP
« Reply #3 on: Mon, 10 November 2014, 18:48:27 »
Only the function keys
Offline Dr.Chipotle
Re: PLS HELP
« Reply #4 on: Mon, 10 November 2014, 18:49:07 »
Ill do that tomorrow when there is daylight so you guys can get a a clear view
Offline jinq-sea
Re: PLS HELP
« Reply #5 on: Tue, 11 November 2014, 08:19:16 »
Might be a short across a couple of switches! Pics will help  :)
Offline Dr.Chipotle
Re: PLS HELP
« Reply #6 on: Tue, 11 November 2014, 16:00:16 »
those are some of the function keys
That is the pcb of the entire board if your just wondering
Another function key  If u can find anything wrong witht his pelase help
Offline Dr.Chipotle
Re: PLS HELP
« Reply #7 on: Sat, 15 November 2014, 07:26:51 »
umm i posted the pictures
Offline Pemdas
Re: PLS HELP
« Reply #8 on: Sat, 15 November 2014, 22:52:53 »
From the pictures it looks like it might be an overheated joint. Repairing overheated joints is pretty straightforward. Remove all solder, take a razor blade or other object and scrape away all the nasty burnt flux. Some isopropyl will help get the stubborn ones out (don't use too much just a dab on a toothpick will be fine)Then just resolder the joint using a lower temp setting. I have my temp set at ~650F. Also keeping a clean tip will go a LONG way to getting clean solder joints. Hope that helps and I wish you luck, but without actually looking at the board not too sure what else it could be.
Offline Dr.Chipotle
Re: PLS HELP
« Reply #9 on: Sun, 16 November 2014, 08:54:21 »
Well thats only for like the function keys, what about the other keys. Is it possible that an overheated joint could affect the keys?
