Author Topic: RealForce 87U keymapping unrecognized when logging into Windows 7?  (Read 1418 times)
Offline kansas city shuffle
« on: Sun, 09 November 2014, 00:04:25 »
I am using my RealForce 87U on my Windows 7 laptop, however something strange happens when it boots up. For some reason when I type in my password it, incorrect, yet when I type it in from my laptop keyboard I login just fine. What gives?
I double check the key mapping once I am logged in and it's fine (everything typed is as expected), and I also tried locking/unlocking the laptop and it works there as well. Only noticing this strange behavior on boot up.  :blank:
Can it be the wrong key mapping is being loaded at startup?  :(
Re: RealForce 87U keymapping unrecognized when logging into Windows 7?
« Reply #1 on: Sun, 09 November 2014, 00:25:04 »
Figured it out, it's the Numlock key that's activated during start up which causes some keys to map as the numpad. Turning the numlock key off;  everything worked as intended and was able to login.
Duh...  :thumb:
« Last Edit: Mon, 10 November 2014, 02:01:27 by kansas city shuffle »
Offline Veridis
« Reply #2 on: Sun, 09 November 2014, 00:50:31 »
This happened to me at work as well.. @_@
Ducky Shine 3 TKL (MX Brown) | CM Rapid-i (MX Brown) | Realforce 87u 45g Uniform | CM Novatouch | Ducky Zero TKL (MX Brown) | Das Keyboard III (MX Blue)
« Reply #3 on: Sun, 09 November 2014, 03:06:19 »
I was going to suggest that some Windows machines do a lazy USB initialisation, and continue to boot the OS even if the USB devices have not come up.
But if you've already resolved it - great!
And thank you for posting the results - it might help someone else with a similar problem.
« Reply #4 on: Mon, 10 November 2014, 02:03:36 »
Yeah it was odd as I dual boot my Windows laptop to Ubuntu 14.04 and Windows 7; the Ubuntu login doesn't turn on the numlock key during the login screen, but the Windows 7 does. <shrugs>
