Author Topic: Currently modifying some forum settings  (Read 9873 times)
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« on: Sun, 09 November 2014, 14:24:25 »
Things might go a bit wonky for 10-15 minutes at a time. At the end of modifying, I will be running routine database maintenance tasks that will bring the forum offline for about 10 minutes.
Please excuse my dust :)
Re: Currently modifying some forum settings
« Reply #1 on: Sun, 09 November 2014, 14:50:56 »
Is this to add SSL support?
Offline heedpantsnow
  • Old enough to know better
« Reply #2 on: Sun, 09 November 2014, 14:57:13 »
I'm back.
Offline mkawa
« Reply #3 on: Sun, 09 November 2014, 15:04:31 »
no, https will require a full down of the service when it's deployed
« Reply #4 on: Sun, 09 November 2014, 15:21:27 »
It's wonky enough as it is - a little bit more wonkiness won't go astray, especially if it helps with some of the problems.
Offline mkawa
« Reply #5 on: Sun, 09 November 2014, 16:30:33 »
ok, very short down incoming
« Reply #6 on: Sun, 09 November 2014, 16:45:46 »
Bring the awesomeness!  Thanks for all the hard work!
I'm back.
Offline mkawa
« Reply #7 on: Sun, 09 November 2014, 16:46:31 »
done. thanks folks
