Author Topic: Novatouch Question  (Read 1279 times)
Offline Harbec
Novatouch Question
« on: Sun, 09 November 2014, 16:00:24 »
I'm kind of curious about this board and if it's compatible with something like http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=281
I used one of these cases for my Quickfire but I'm not sure the Novatouch would fit the case. Anyone know?
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Novatouch Question
« Reply #1 on: Sun, 09 November 2014, 16:03:14 »
It does not fit *any* TKL case that isn't the case it comes in.  It's a micro usb port and the port is in a different spot, too.  The plate is also different.
THOUGH, you might be able to plug the mini port that case comes with into the daughterboard where the micro usb port plugs in on the novatouch.  I don't think it will fit overall, though.
Offline Freebird
    • SSRCG
« Reply #2 on: Mon, 10 November 2014, 16:52:10 »
Would be awesome if it would fit in something a bit nicer. That Tex case is delicious.
I just ordered myself a Novatouch and have already been thinking what I can do to improve it, other than the obvious new keycaps.
