Author Topic: Rubberdome or mechanical  (Read 1773 times)
Offline Touch_It
« on: Sun, 09 November 2014, 17:26:27 »
appears to be rd but wanted to make sure
Offline dante
Re: Rubberdome or mechanical
« Reply #1 on: Sun, 09 November 2014, 18:39:47 »
Likely rubberdome.  Always ask the seller to remove a keycap to be sure.  If they refuse - F them.
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #2 on: Sun, 09 November 2014, 21:47:10 »
I say rubberdome. I remember those, nothing special.
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline Touch_It
« Reply #3 on: Sun, 09 November 2014, 21:48:40 »
Didn't have the seller pull a keycap but he said it felt like a "new style" keyboard so I passed.  Thanks
« Reply #4 on: Sun, 09 November 2014, 22:15:55 »
The odd size of the Esc key also leans towards this being membrane.
Offline davkol
  •  Post Editing Timeout
« Reply #5 on: Mon, 10 November 2014, 06:47:53 »
Apparently, FDA-102A has Alps. What does the I stand for then?
Offline 00zeRO
« Reply #6 on: Mon, 10 November 2014, 07:27:27 »
"Inexpensive"
"Inadequate"
"Inhumane"
Offline JDorfler
    • My Blog
« Reply #7 on: Mon, 10 November 2014, 12:27:20 »
If you can get it for 5 bucks you could always use it for target practice.
Offline jinq-sea
« Reply #8 on: Tue, 11 November 2014, 06:44:15 »
I'm sure I had one of these and it was rubber dome. Please say it is, else I threw away an alps keyboard years ago...  :'(
