Author Topic: Pang  (Read 2221 times)
Offline Blackehart
Pang
« on: Mon, 10 November 2014, 13:22:21 »
So I have a ducky with tactile greys.
I'm experiencing something I haven't before with any other switch type (red, brown, black, clear, blue, green or whites).
I get a metallic pang from releasing the keys.
It is more pronounced the farther up that row is from the bottom of the case (it almost non-existent on the bottom row but more pronounced on the number row and the function row).
I just cut out some of that thick non-adhesive shelf liner and put that in. While it lessened the pang, I can still hear it.
is there anything i can do to get rid of it or is this something that i will have to live with?
Thanks,
-Blacke
Offline exitfire401
  • The Force is Re/\l
Re: Pang
« Reply #1 on: Mon, 10 November 2014, 13:23:23 »
Thanks,
-Blacke
That's usually from the springs. You can try oiling them, but it will more than likely continue to occur.
Re: Pang
« Reply #2 on: Mon, 10 November 2014, 13:23:32 »
Welcome to tactile grays. All of mine make a 'spring' noise.
Offline Blackehart
Re: Pang
« Reply #3 on: Mon, 10 November 2014, 13:26:16 »
awww, fishsticks...
Was afraid you'd say "live with it".
Re: Pang
« Reply #4 on: Mon, 10 November 2014, 13:27:45 »
awww, fishsticks...
Just think of it as a feature.
Offline C5Allroad
  • Formerly HUNTERANGEL121
Re: Pang
« Reply #5 on: Mon, 10 November 2014, 16:05:38 »
awww, fishsticks...
Just listen to music while you type lol.
  • Live long and prosper
Re: Pang
« Reply #6 on: Mon, 10 November 2014, 16:08:54 »
Is there a difference between ping and pang?
tp thread is tp thread
Re: Pang
« Reply #7 on: Mon, 10 November 2014, 16:10:14 »
Pong?
Ping pong pang?
Musical keyboards :))
Offline Blackehart
Re: Pang
« Reply #8 on: Mon, 10 November 2014, 16:47:27 »
well...
I could hear a ping when hitting a key that had one of the costar stabs.
The pang from the greys is different and "actually" sounds like a pang.
Re: Pang
« Reply #9 on: Mon, 10 November 2014, 22:23:29 »
The tactile gray has a different sound than typical ping.
Offline Jalberstone
Re: Pang
« Reply #10 on: Tue, 11 November 2014, 00:03:16 »
What keyboard specifically are you using?
Offline Blackehart
Re: Pang
« Reply #11 on: Tue, 11 November 2014, 02:05:17 »
ducky shine 3.
Modded from reds to tactile greys.
Offline JDorfler
    • My Blog
Re: Pang
« Reply #12 on: Tue, 11 November 2014, 03:19:25 »
I really don't here pang when I type.  I here more of a pthunk.  Yes, a pthunk.  Then again I've had explosives go off near me more than I'd like to admit.  Maybe my hearing is a bit skewed.
