Author Topic: Perfect computer setup for the great outdoors  (Read 1452 times)
Offline BlackWidowMan777
« on: Mon, 10 November 2014, 16:42:33 »
What would be the perfect setup for on-the-go-computing without a readily available powersupply?
This would be perfect for use in the car, on camping trips, even while fishing.
Powersupply would be something like this: https://www.indiegogo.com/projects/chargeall-world-s-smallest-portable-power-outlet
laptop/tablet/hybrid: ??
mechanical keyboard: ??
Caveat: my dream setup would be rugged enough to keep in the boot at all times.
Offline johndavis33
Re: Perfect computer setup for the great outdoors
« Reply #1 on: Mon, 10 November 2014, 17:56:50 »
For a boat type thing, you'll probably want one of those Panasonic toughbook type laptops.
For a more reasonable set up, you might want to check out a thinkpad x220 with a slice battery. The x series sips power, and all thinkpads are made of tougher stuff than the average laptop. I have the tablet varient, and it gets about 13-15 hours on a single charge. The non tablet version is supposed to have better battery life and is supposed to be more rugged.
I use an hhkb with mine, since I can put it right on top of the keyboard and have it fit perfectly. But honestly, unless I'm writing something major, I just use the laptop's built in keyboard. It's better than some mechanical keyboards I've tried, and the trackpoint is better than any trackpad.
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
« Reply #2 on: Mon, 10 November 2014, 18:53:38 »
Thanks for the heads-up on the slice battery. I wonder if it will fit on the upcoming MSI GT80 Titan laptop?
Personally, I've always liked the look of the Getac series of toughbooks/rugged laptops.
I just wonder whether these would be able to withstand the temperature of the Australian summer while sitting in the boot of my car (32 C in the shade).
Offline johndavis33
« Reply #3 on: Mon, 10 November 2014, 19:12:30 »
I've only seen slice batteries for later x series thinkpads. I don't think any gaming laptop will fulfill your needs. I know thinkpads have drainage channels or water. I think some model m's have them too. They're designed to use route water that gets on the keyboard around the motherboard without touching it, only really works i it's right side up. As or heat, I've seen some very unscientific tests where they've survived being baked in an oven.
