Author Topic: Current keyboard design favors left-hand mouse users  (Read 5668 times)
Offline Veridis
« on: Mon, 10 November 2014, 22:43:46 »
Being the majority, right handed people really screwed themselves over with the design of the keyboard and mouse. In the past there was no mouse, so the navigation cluster and numpad were put on the right. Now that we have the mouse, why are these keys not moved to the left?
The way keyboards are designed currently really favors people who use a mouse on the left side.
I use the mouse with my right hand, and even with a TKL keyboard, it is so awkard to have to move my left hand all the way to the right just to use the navigation cluster (and the keys above it) and the mouse at the same time.
People are resorting to small form factor keyboards to avoid this problem, at the cost of losing functionality. And for small keyboards that still have the arrow cluster, they are still put on the right.
The only way to fix this is to get a smaller form factor keyboard and a separate numpad.
« Last Edit: Mon, 10 November 2014, 22:58:55 by Veridis »
Ducky Shine 3 TKL (MX Brown) | CM Rapid-i (MX Brown) | Realforce 87u 45g Uniform | CM Novatouch | Ducky Zero TKL (MX Brown) | Das Keyboard III (MX Blue)
Offline divito
Re: Current keyboard design favors left-hand mouse users
« Reply #1 on: Mon, 10 November 2014, 23:00:54 »
Not sure I can totally agree here; and besides that, you move your left hand to the 6-key????
Mice are used for navigation purposes, which is on my right-handed side. And the 6-key and arrows are also on the right side, which are for navigation purposes. Rather than scroll with my mouse, I can use my right hand for PgUp, PgDn/Home, End. Rather than clicking for cursor position, I can use the arrow keys.
« Last Edit: Mon, 10 November 2014, 23:10:05 by divito »
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline swathe
« Reply #2 on: Mon, 10 November 2014, 23:04:04 »
The mouse came after the keyboard anyway so I feel the current design is the best (for right handed people anyway re numpad location).
I try to limit the amount I have to use the mouse which is why I'm a fan of tiling window managers.
DAS Professional MX Blue
Razer Black Widow Ultimate 2013 Edition MX Blue
Linux + Emacs
Offline Veridis
« Reply #3 on: Mon, 10 November 2014, 23:25:25 »
Hmm, when just doing work (programming, querying databases, looking at logs etc) I find it very helpful to use the mouse together with arrows/home/end/page down/page up.
In order to use the mouse and 6-key/arrows at the same time, I have to move my left hand to the right.
Offline frosty
  • jukebox hero
« Reply #4 on: Mon, 10 November 2014, 23:29:46 »
But left handed find it annoying to use wasd.
Offline Veridis
« Reply #5 on: Tue, 11 November 2014, 00:03:27 »
Wasd can be remapped to other keys on the right side for most games.
Offline FoxWolf1
  • 154
« Reply #6 on: Tue, 11 November 2014, 00:54:00 »
This is why I think that the Focus FK-7000P layout might be advantageous:
Mouse and arrow/navigation keys accessible simultaneously, all the time.
Mouse and arrow/navigation keys accessible while also using the numberpad with the right hand, which is usually dominant.
Mouse and main key cluster close together.
« Last Edit: Tue, 11 November 2014, 00:55:46 by FoxWolf1 »
Offline Oobly
« Reply #7 on: Tue, 11 November 2014, 01:03:04 »
That's why 60% rocks. Especially if it's programmable. Can use navigation on either left or right, depending on your own preferences.
I use arrows and edits with my right hand, but it's always either mouse for navigation or keys, not together, so a normal TKL works for me. I prefer 60%, though because I can have the mouse closer and centre the alpha keys to the screen.
If you want to use navigation and mouse at the same time you could get a left-handed keyboard: http://www.dsi-keyboards.com/dsi-left-handed-keyboard-usb-with-cherry-mechanical-key-switches.aspx
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline davkol
  •  Post Editing Timeout
« Reply #8 on: Tue, 11 November 2014, 04:55:50 »
That's why symmetrical layouts rock. Embedded tenkey without losing anything, more space on both sides.
Offline jinq-sea
« Reply #9 on: Tue, 11 November 2014, 06:42:39 »
For me, even as a southpaw, left hand does typing and shortcuts and mouse does navigating - I also never use mouse and keys together for nav :)
Offline Veridis
« Reply #10 on: Tue, 11 November 2014, 07:29:07 »
Looks like I'm just weird!  :p
Offline jinq-sea
« Reply #11 on: Tue, 11 November 2014, 07:33:19 »
Not at all! It wouldn't do if we were all the same, anyway!
Offline Data
« Reply #12 on: Tue, 11 November 2014, 08:29:07 »
I'm a righty.  Doesn't bother me.  If I need to switch to arrow keys / nav cluster I just move my hand off the mouse.  I've never needed to use both at the same time.
Offline dusan
« Reply #13 on: Tue, 11 November 2014, 09:18:24 »
Absolutely. Small form factor, num pad under left hand, nav pad under left hand, and any other support for one-hand, any-hand keyboarding (without sacrificing comfort of both-hand keyboarding) are the primary ergonomic requirements of enterprises nowadays.
Unfortunately, such keyboards do not exist (yet).
A typical small form factor keyboard (e.g. Filco Minila or Matias Ergo Pro) works like a tank, with two drivers: even pretty simple combination such as Ctrl+Backspace requires two hands to complete.
The standard keyboard works like a taxi: the only driver (the right hand) controls everything. With the right hand, even Ctrl + Alt + Delete is possible.
But, for the sake of productivity, modern enterprises need something like a commercial airplane, which can be controlled by both, or either of the two pilots.
That's why I've proposed these:
http://geekhack.org/index.php?action=dlattach;topic=62339.0;attach=81543;image
http://geekhack.org/index.php?action=dlattach;topic=64580.0;attach=81546;image
« Last Edit: Tue, 11 November 2014, 09:32:30 by dusan »
Topre Type Heaven | Filco Majestouch w/MX blue | CM Storm QF w/MX green | Asus Echelon w/MX black | Razer Tournament 2014 w/Razer green, Keychron K1 w/Gateron LP red | TypeMatrix 2030 | custom 6x16 ortho w/MX black | Atreus 44 w/Kailh box white & Gateron Pro yellow.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #14 on: Tue, 11 November 2014, 09:37:05 »
No, they're not.  And there's very little reason to believe they ever will be.
Offline jinq-sea
« Reply #15 on: Tue, 11 November 2014, 09:43:54 »
Actually - just thinking about that, I would move my left hand to the arrow block if I wanted to move between cells in Excel or something like that, while using the mouse to change options. I reckon an arrow block on the LHS would feel well odd for me though...
Offline quake4mhg
« Reply #16 on: Wed, 12 November 2014, 00:19:41 »
Veridis, you're not alone. I'm 100% agree with your title :)
I'm right handed, but use left hand enter numbers & keyboard shortcuts (thanks for G19).
Right hand never leave my mouse (thanks gaming). FYI, I'm using naga with 12butons.
Below are my current setup.
numpad+Race or DSI left hand Cherry MX red.
I guess we're not weird ? :D
« Last Edit: Wed, 12 November 2014, 00:27:22 by quake4mhg »
Offline Liar
« Reply #17 on: Wed, 12 November 2014, 06:16:17 »
Looks like DSI was thinking on your wave length
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=25
Layout seems doable
(Edit: Beaten by seconds)
« Last Edit: Wed, 12 November 2014, 06:17:53 by Liar »
« Reply #18 on: Wed, 12 November 2014, 07:24:40 »
What?
I assumed that this thread was about why it is better to mouse with the left hand.
I made the switch a few years ago and was delighted, even though my right hand is very strongly dominant.
As I later discovered the joy of the Wow Joy Pen mouse, available only in right-hand configuration, I added it.
Now I keep mice on both sides and use whichever one is most convenient at the moment.
When a fool gains power, the first thing he does is silence the wise.
The Next thing he does is gather other fools around him.
The final thing he does is destroy the Nation.
- Plato
Offline divito
« Reply #19 on: Wed, 12 November 2014, 07:40:05 »
Layout seems doable
I kinda almost want 6-key and arrows on the left side, 10-key on the right, just to try it out.
Offline Liar
« Reply #20 on: Wed, 12 November 2014, 09:16:56 »
Edit: I misread your post and you will find these are not the keyboards you are looking for, left links for any interested parties
These have Numpad on Left, Arrows on Right
http://www.amazon.com/gp/product/B000EMC1HY/ref=s9_simh_gw_p147_d0_i4?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1X0FA29VR69ZNRB1V5SV&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846
http://www.amazon.com/gp/product/B007YW7Z0U/ref=s9_simh_gw_p147_d0_i5?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1X0FA29VR69ZNRB1V5SV&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846
The latter has oddly shaped keys however
« Last Edit: Wed, 12 November 2014, 09:22:13 by Liar »
Offline quake4mhg
« Reply #21 on: Wed, 12 November 2014, 09:44:17 »
Layout seems doable
Maybe this?
http://www.ione-usa.com/ione-scorpius-32-cherry-mx-mechanical-key-switch-numeric-keypad.html
OR similar topic about Ducky Legend
http://geekhack.org/index.php?topic=45685.0
« Last Edit: Wed, 12 November 2014, 09:47:21 by quake4mhg »
Offline divito
« Reply #22 on: Thu, 13 November 2014, 11:23:16 »
That would have been awesome if it had gotten released.
Offline dusan
« Reply #23 on: Thu, 13 November 2014, 11:37:12 »
The left side tenkeys are not left-hand. They're just right-hand tenkeys put on the wrong side.
For most users, this is a mistake.
