Author Topic: Prototype Arc Reactor  (Read 9450 times)
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« on: Tue, 11 November 2014, 12:33:38 »
I know this has been attempted in the past, but not like this. The idea would be to have the keycap made out of metal. Of course light bleeds through the holes
This is the 3d prototype
Thoughts? Suggestions?
Re: Prototype Arc Reactor
« Reply #1 on: Tue, 11 November 2014, 12:35:06 »
I wonder if you could print a little translucent cover to fit over the hole so you can get an LED to cast a glow through the cover. That way you'd get a wonderful diffused light instead of just an LED poking through.
Offline engicoder
« Reply #2 on: Tue, 11 November 2014, 12:48:34 »
Might be easier to have a recess on the underside of the cap with the translucent piece there. The edges of the piece would then be hidden. Probably 3d print both pieces.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #3 on: Tue, 11 November 2014, 13:56:10 »
yes, that would be possible, but not with a cherry/DCS profile (due to the not-centered stem position). I'd need to work on a SA-like or DSA-like profile to have that working.
« Reply #4 on: Tue, 11 November 2014, 14:05:44 »
At that point, wouldn't you just be doing Martin's "Armor" caps?
Offline 0100010
  • Not Sure
« Reply #5 on: Tue, 11 November 2014, 15:56:40 »
Awesome design.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #6 on: Tue, 11 November 2014, 17:12:08 »
is someone working on something similar? I've seen an iron keycap, but definitely a different concept.
Offline HPE1000
  • Keycap Paparazzo
« Reply #7 on: Tue, 11 November 2014, 17:16:27 »
They have been in a couple sales so far, afaik.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #8 on: Tue, 11 November 2014, 17:21:07 »
yeah that's what I've seen. Definitely not the same design :) Also mine would be out of metal (if it will ever happen...)
Tomorrow I'll try to make a 2 pieces keycap, with a plastic insert to diffuse the light. Might be interesting
Offline engicoder
« Reply #9 on: Tue, 11 November 2014, 17:21:34 »
I believe he is referring to this: http://geekhack.org/index.php?topic=59800.0
Offline ConscienceDrop
  • a-are these pbt?
« Reply #10 on: Tue, 11 November 2014, 17:25:32 »
looks nice as hell.
im not a fan of the subject material so i would probably pass on this but its beauty cant be denied and its very understated so would look amazing on more minimalist boards where novelties usually stand out too much!
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #11 on: Tue, 11 November 2014, 17:27:44 »
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #12 on: Wed, 12 November 2014, 09:50:42 »
now with plastic insert!
« Reply #13 on: Wed, 12 November 2014, 09:51:57 »
Ooooo, would love to see that lit up :)
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #14 on: Wed, 12 November 2014, 09:56:17 »
I'm going to order one on shapeways!
Offline heedpantsnow
  • Old enough to know better
« Reply #15 on: Wed, 12 November 2014, 09:56:36 »
Sweet.  I can see how sby would think this is copying Martin's.  I can also see that it's sufficiently different.
Would be cool if it had a really thin dashed line in the "wires" running up the side to light them up a bit.  Can do that kind of thing with 3d printing that would be a pain to machine that small.
I'm back.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #16 on: Wed, 12 November 2014, 10:41:15 »
please note that I'm not a vendor. I'm doing this for me and few folks who want it. Anyway the designs seem pretty different to me.
Offline 3Love
  • Bumpino Supremo
  • I want to become a great collector. Greedy!!!
    • https://geekhack.org/index.php?topic=63161.0
« Reply #17 on: Thu, 13 November 2014, 13:49:50 »
If you can make the metal keycap clearly like the picture, I believe it's really good product.
I♥Keyboard  I♥Clack  I♥Brobot  I♥Hammer
                          I♥♥♥friends
【WTB/WTTF】https://geekhack.org/index.php?topic=63161.0
KBD Collection: 356CL, 356.2, 356DGE, Koala, 356MINI, 356N, 356N-MK2, 356PAD, 360C, 456GT, FMJ, LZ-MXSE, LZ-RE, KMAC 1.0, KPAD, Duck Orion, Duck Pad, Exo, TEX and etc.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #18 on: Thu, 13 November 2014, 16:48:00 »
This is an automated preview on shapeways. Unfortunately it's not from top. Anyway it should be ready by the end of the month.
« Last Edit: Thu, 13 November 2014, 16:49:32 by Matt3o »
Offline twiddle
    • Portfolio
« Reply #19 on: Thu, 13 November 2014, 18:47:19 »
Using Rhino for the model? I recognise the grid. Rhino was the first 3d application I learnt.
Oh, and the cap looks great - I'll be curious to see how the detail translates to sintered metal.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #20 on: Fri, 14 November 2014, 01:26:44 »
yes that would be rhino, not a huge fan, but I had a very old license and keep using it.
Offline GenKaan
  • Mer caps, mindre k踀bel
« Reply #21 on: Fri, 14 November 2014, 04:18:41 »
Looks nice but it does look very similar to the Armor Cap, would love to see it in person :)
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #22 on: Sat, 15 November 2014, 09:42:09 »
+1
No suggestions, just a comment, "That's awesome!"
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #23 on: Sun, 16 November 2014, 18:55:42 »
overmold something translucent over each metal cap. if you're going to make this with your router though start with cast metal blanks...
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #24 on: Mon, 17 November 2014, 01:46:26 »
this is actually a good idea. not sure how to prevent the resin to bleed over the metal on the top though
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #25 on: Tue, 25 November 2014, 04:29:33 »
YES! Shapeway just shipped 2 arc reactors :)
I'll get them in a couple of days! Can't wait!
Offline Evo_Spec
  • (╯�ヮ�)╯︵⌨
« Reply #26 on: Tue, 25 November 2014, 05:47:45 »
Very cool, can't wait to see it!
GON NerD TKL DTA Edition
Offline mkawa
« Reply #27 on: Tue, 25 November 2014, 06:41:25 »
achtung matt3o! i want one!
Offline 00zeRO
« Reply #28 on: Tue, 25 November 2014, 10:26:57 »
Ja, das ist stimmt! Kommen das bitte!
Offline GankIndustries
« Reply #29 on: Tue, 25 November 2014, 11:25:07 »
Damn, that is sexy.
Poker 2 Clears
V2 Reds
60% Alps loading
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #30 on: Thu, 27 November 2014, 05:54:57 »
I got it!
The plastic insert doesn't work. Metal 3d print is too irregular to fit such a small insert. It would still be possible to throw some resin inside the holes but it works pretty well barebone actually.
I'm not 100% satisfied by the print quality, the pumpkin came out better, but well a nice addition to my collection nonetheless :P
Offline Evo_Spec
  • (╯�ヮ�)╯︵⌨
« Reply #31 on: Thu, 27 November 2014, 07:08:49 »
It's nifty lookin!
Too bad the insert didn't work, would have loved to see that.
Offline 00zeRO
« Reply #32 on: Thu, 27 November 2014, 09:43:46 »
I got it!
Are these available for purchase on shapeways? I'm unfamiliar with how that all works...
Very cool though.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #33 on: Thu, 27 November 2014, 09:51:41 »
I haven't put this on sale yet.
