Author Topic: basic full keyboard dwg?  (Read 5233 times)
Offline neverused
« on: Tue, 11 November 2014, 15:15:05 »
Hello,
I was wondering if anyone had a basic full keyboard dwg that I could use as a basis to edit?  I would like to add a few keys and have it cut from 1.5mm acrylic, using the stabs from wasdkeyboards.com.  Is there an available resource such as this?  I haven't found one in my searching yet.
Best,
neverused
Example:
Re: basic full keyboard dwg?
« Reply #1 on: Tue, 11 November 2014, 15:22:07 »
Did you check the CAD resources thread?
Offline neverused
« Reply #2 on: Tue, 11 November 2014, 16:49:44 »
All that I saw was a layout with keycaps, what I was looking for was a mocked up plate if possible.
« Reply #3 on: Tue, 11 November 2014, 20:24:18 »
http://deskthority.net/workshop-f7/tiny-javascript-keyboard-layout-editor-t5110.html
Code: [Select]
Esc::1  __::1  F1::1  F2::1  F3::1  F4::1  __::0.5  F5::1  F6::1  F7::1  F8::1  __::0.5  F9::1  F10::1  F11::1  F12::1  __::0.5  Prtsc::1  Scrlk::1  Pause::1$$
~::1  1::1  2::1  3::1  4::1  5::1  6::1  7::1  8::1  9::1  0::1  -_::1  +=::1  Backspace::2  __::0.5  Insert::1  Home::1  Pgup::1  __::0.5  NumLk::1  /::1  *::1  -::1$$
Tab::1.5  Q::1  W::1  E::1  R::1  T::1  Y::1  U::1  I::1  O::1  P::1  [{::1  ]}::1  \|::1.5  __::0.5  Del::1  End::1  Pgdn::1  __::0.5  7::1  8::1  9::1$$
Caps Lock::1.75  A::1  S::1  D::1  F::1  G::1  H::1  J::1  K::1  L::1  ;: ::1  '"::1  Enter::2.25  __::4  4::1  5::1  6::1$$
Shift::2.25  Z::1  X::1  C::1  V::1  B::1  N::1  M::1  <,::1  >.::1  /?::1  Shift::2.75  __::1.5  ^::1  __::1.5  1::1  2::1  3::1$$
Control::1.25  Win::1.25  Alt::1.25  Space::6.25  Alt::1.25  Win::1.25  Menu::1.25  Control::1.25  __::0.5  <::1  V::1  >::1  __::0.5  0::2  .::1 $$
http://ne0.cc/laygenV2#h9lVt
Press "download dxf WORK IN PROGRESS"
add the 2-unit vertical keys enter and + from the GH cad resources hub
Or just wait for swill to get done with his awesomeness.
Offline neverused
« Reply #4 on: Tue, 11 November 2014, 22:53:41 »
Wow thank you!
Offline roman.heredia.12
« Reply #5 on: Thu, 13 November 2014, 22:51:56 »
« Reply #6 on: Thu, 13 November 2014, 23:05:08 »
Graviela renteria
Offline tutuling
« Reply #7 on: Sun, 16 November 2014, 02:13:35 »
Good resource there!
