Author Topic: [.de] Funky Kyocera keyboard  (Read 4227 times)
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« on: Sat, 18 July 2009, 20:04:30 »
Listing
Has an interesting shape in any case (pun not intended). Never seen such a thing. Any idea what it might be?
Offline watduzhkstand4
« Reply #1 on: Sat, 18 July 2009, 21:01:25 »
For some reason it makes me think it uses Cherry switches.... but I've never seen that before.
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline huha
« Reply #2 on: Sat, 18 July 2009, 22:33:39 »
The keycaps look suspicious. Integrated LEDs and strange rectangular cutouts could point to a Fujitsu Peerless board. The ferrite core on the cable is a bit unusual, I've got one as well on my Fujitsu Peerless board (Epson). Also, kyocera are Japanese, so it might be a Fujitsu Peerless board after all. But!
It's flat. That's quite unusual for a Fujitsu Peerless board, they're usually curved. Get the model number. If it's a Fujitsu Peerless, you'll know instantly.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline keyb_gr
  • Cherrified user
« Reply #3 on: Sun, 19 July 2009, 07:25:36 »
It might well be an OEM'd Fujitsu then (the keycap color would also point to that). I imagine they offered semi-custom builds similar to Cherry.
Offline sixty
    • http://deskthority.net
« Reply #4 on: Tue, 21 July 2009, 06:27:53 »
No one got it? How disappointing. I didn't grab it cause I figured someone else here would :(
Offline keyb_gr
  • Cherrified user
« Reply #5 on: Tue, 21 July 2009, 15:28:45 »
It's baaack...
Not that interested myself. I still need something with SMK switches, and otherwise I prefer to stick with common Cherry boards. That Kyocera space ship is a little on the bulky side.
