Author Topic: HHKP2 issues  (Read 3089 times)
Offline Bluemercury
HHKP2 issues
« on: Sun, 19 July 2009, 12:52:59 »
Today is just turned my laptop on, and i found that the "zxcv..." row of keys wasnt registering. I thought this odd, so i removed and then plugged in the cable again, and it seemed to solve whatever problem it was. Also does the HKKP2 lacks any type of NUMLOCK way of input? When i activate the numlock in my laptop there's the iopjklm keys that turn into numbers but this doesnt seem to happen when i turn the numlock on in the laptop keyboard and press those keysin the HHK, which was what it make me to think that there is no NUMLOCK feature here. My main question is if there«s no NUMLOCK feature here.
Collection:
Das Keyboard II
Model M5-2
Model M5-1(considering selling this one)
Cherry G80-3000LCMPO with black switches
Cherry G80-5000HAMPO (Brown switches)
McAlly96
HHKP2 BNx2
Offline lam47
HHKP2 issues
« Reply #1 on: Sun, 19 July 2009, 16:06:04 »
I have noticed similar things with mine. I have turned it on to find that it has a numlock on? and the uiojlknm ish keys are inputting numbers and some others nothing. I just unplug and plug it back in when it does this.
What OS do you run?
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline Bluemercury
HHKP2 issues
« Reply #2 on: Sun, 19 July 2009, 16:48:25 »
Quote from: lam47;103300
What OS do you run?
Right now im with XP pro. But the thing is this keyboard doesnt even have a numlock key. it does have the caps and scroll lock.
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline JBert
HHKP2 issues
« Reply #3 on: Mon, 20 July 2009, 14:41:02 »
Quote from: Bluemercury;103282
This numpad-emulation of your laptop keyboard is probably done by its keyboard controller, so the HHKB cannot use this functionality.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline lam47
HHKP2 issues
« Reply #4 on: Mon, 20 July 2009, 17:54:13 »
Its an odd one for sure.
I have also found that with my HH. It will not register any inputs when I initially boot the system. I have to press some keys and wait before it will start typing.
And it has done this with 3 motherboards and 3 different OS's.
I think the HH PCB is just a bit of a strange one.
Offline rdjack21
HHKP2 issues
« Reply #5 on: Mon, 20 July 2009, 18:35:40 »
Most mother boards with a PS/2 connector do not enable USB keyboard suppport by default. So you can't use your HHKB Pro until the OS boots up and installs a keyboard driver. So if you want to use your HHKB Pro before the OS boots you need to enable it in the BIOS. But be warned some older mother boards do not have this feature and expect you to use a PS/2 keyboard if you want to edit or modify the BIOS settings.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
HHKP2 issues
« Reply #6 on: Mon, 20 July 2009, 21:44:07 »
Neither HHKB Pro 2 I've owned has ever given me any trouble in OS X. I've even used it to trigger Boot Camp (XP Pro).
Offline lam47
HHKP2 issues
« Reply #7 on: Tue, 21 July 2009, 03:42:10 »
It works fine in the bios. Again though I have to hit delete a few times before it will register an input.
Or say I have had a windows crash and I get to the boot screen.
To pick start windows normally I have to press enter about 5 times.
Both of the HH keyboards I have had have done this.
I have USB keyboard support on in the BIOS :)
AAAAAAAAAAAAAnnyway. I don't know if any of this is helping the op.
Offline Bluemercury
HHKP2 issues
« Reply #8 on: Mon, 27 July 2009, 18:30:30 »
Sorry for late reply, but i havent had any other problems with it, i just found odd what was happening....
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
