Author Topic: Why Are These So Much Cheaper?  (Read 1225 times)
Offline notsonerd
  • Here for the secrets
  • Light My Fire
« on: Fri, 14 November 2014, 03:39:37 »
Comparing the 104 Key Black Translucent PBT + POM Doubleshot Keycap Set (Vortex) and the Black - PBT Double Shot Keycap Set (Vortex), what makes the non-backlit compatible keycaps almost twice as expensive?
I only own the white translucents keycaps and they feel awesome for my first PBT set, I just don't get why they're so cheap in comparison to the other set.
KBParadise V60 with Cherry MX Browns | Corsair K60 with Cherry MX Reds
Offline Oobly
Re: Why Are These So Much Cheaper?
« Reply #1 on: Fri, 14 November 2014, 05:21:13 »
Could be that since the WoB doubleshots are PBT for both materials, whereas the backlit compatible uses POM for the "clear" part? AFAIK, PBT is a tricky material to work with due to it's thermal expansion coefficient and tendency to warp if cooled to quickly, so the molds have to be designed specifically for use with it.
Also, the PBT in the backlit compatible caps may well be a blend to minimise these effects, so they can use cheaper molds?
All pure speculation, there could be other simple business reasons for it, too, since the doubleshot PBT sets were made first and they could be using the same molds for the backlit sets, but since they have to recoup the costs of the molds from the first sets made with them, the doubleshot sets had a higher initial price set. Lots of possibilities.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
