Author Topic: Broken Key  (Read 1591 times)
Offline Chornicle
Broken Key
« on: Sat, 15 November 2014, 00:00:29 »
So my "B" Key started acting weird out of no where.
When i type "B" But only lower case it'll type "wwwwwwwwww"
But when i type "B" upper case it doesnt do it
This started happening completely random and its extremely annoying.
Any ideas how to fix it?
http://www.newegg.ca/Product/Product.aspx?Item=N82E16823162029&cm_re=TT_esports-_-23-162-029-_-Product
This is the keyBoard i have.
Offline BlueBär
Re: Broken Key
« Reply #1 on: Sat, 15 November 2014, 05:16:37 »
Sounds like a broken controller to me. Which would not be fixable, because afaik there are no replacement controllers for that board.
Offline shut up
Re: Broken Key
« Reply #2 on: Sat, 15 November 2014, 09:41:44 »
You probably could contact Newegg, or whenever you bought it and see if they can honor it or something.
IBM Model M 42h1292 (Bolt mod, but still broken Yaaaayyyy) | Adesso Mkb-125b MX blues | Alienware Tactx (D0me5.)
