Author Topic: Can you swap Ctrl and Caps-Lock on the Poker II?  (Read 2694 times)
Offline ViciousWhiskers
« on: Sat, 15 November 2014, 00:07:11 »
I'm thinking of getting a Poker II, but was wondering if you can do that. I've searched around and have seen people say that they're "fully programmable," but in this context what does fully programmable mean?
Knock Knock.
Race Condition.
Who's there?
Offline ynrozturk
Re: Can you swap Ctrl and Caps-Lock on the Poker II?
« Reply #1 on: Sat, 15 November 2014, 00:29:04 »
Nope. Perhaps with some software you could.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline Rainbow_
« Reply #2 on: Sat, 15 November 2014, 01:39:11 »
You can use software like the guy above me said. Try SharpKeys, it writes changes to the registry, and is not some dinky little program like AutoHotkey ;)
« Reply #3 on: Sat, 15 November 2014, 01:45:25 »
On a mac you can change it in system preferences but I don't know about windows. I can try the programmable layer tomorrow.
« Reply #4 on: Sun, 16 November 2014, 19:57:18 »
The third dip switch on the poker swaps the left ctrl and the caps lock, hope that helps.
Offline Fnzzy
« Reply #5 on: Sun, 16 November 2014, 20:38:52 »
Doesn't it swap Win and Caps Lock?
« Reply #6 on: Sun, 16 November 2014, 21:25:18 »
You're right, I messed that one up.
Offline kohi
« Reply #7 on: Sat, 22 November 2014, 18:35:17 »
i just use the programming layer to swap them, but you have to turn on the pn layer whenever you startup your computer (fn+right shift). ive gotten used to it so it isnt too bad...but it gets annoying haha
Offline Tiramisuu
« Reply #8 on: Sat, 22 November 2014, 19:15:30 »
autohotkey
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
