Author Topic: DSA Size? Compatibility with costar stabs  (Read 2369 times)
Offline awhitedev
« on: Sat, 15 November 2014, 15:57:28 »
I had some issues using some thick Leopold PBT keycaps with costar stabilizers before... they'd get stuck on the wire and it was awful.
I have a set of DSA granite keys coming in sometime in the next month and I'm just wondering:
  • Do Signature Plastic's DSA caps cause issues with costar stabilizers? Has anyone tried it before?
  • Are Signature Plastic's DSA caps 1.5mm thick or are they thinner than that?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: DSA Size? Compatibility with costar stabs
« Reply #1 on: Sat, 15 November 2014, 16:38:57 »
I have had a set of DSA PBT blanks from SP on costar stabs with zero issue on two different boards.  One was a third gen Das, and the other was a Rosewill.
« Reply #2 on: Sat, 15 November 2014, 17:44:35 »
I had SP Granite DSA on Costar (QFS) with no issues at all.
Also the tightness issues seem to been resolved - none of the keycaps were stuck when I tried to remove them.
Offline awhitedev
« Reply #3 on: Sat, 15 November 2014, 18:16:52 »
Good to know! Glad to hear they won't cause any issues.
Offline meow a cat
  • Resistance is futile.
« Reply #4 on: Mon, 17 November 2014, 17:00:58 »
I'm using SP PBT DSA on a JD40 with a Costar spacebar, and no issues here!
Boards:
