Author Topic: Custom Keycaps for daskeyboard model s prefessional  (Read 2037 times)
Offline the caster
« on: Sun, 16 November 2014, 12:04:55 »
Greetings.
I own a das Keyboard Model S Professional over 1 year now and i do want to replace the normal (labeled) keycaps with blank ones (Similar to their ultimate version). Since it has some Mutimedia keys implemented there is a different arrangement (4 slim keys instead of 3 on the left side of the spacebar).
First of all it would help me out a lot if one of you has done the same and can tell me where he bought which caps. Otherwise i hope that you can help me out a bit in terms of how to figure out which caps i have to order since im sure i have to get all of them individually.
P.S. Im not a native speaker so don't be afraid to ask if something is unclear :P
Thanks alot,
Florian
