Author Topic: Mstone Groove87 Spacebar Compatibility  (Read 3282 times)
Offline edwardpark8
« on: Sun, 16 November 2014, 12:54:33 »
Hey guys, I wanted to switch out the spacebar from the Mstone Groove87 with a WASD custom spacebar. Are the spacings on the Mtouch keyboard standard with 50mm spacings or is it like the Leopold keyboards where one has to use universal spacebars? Thanks for any help!
EDIT: http://mstonekr.com/front/php/product.php?product_no=204&main_cate_no=1&display_group=2 is the website for the keyboard
« Last Edit: Sun, 16 November 2014, 13:41:04 by edwardpark8 »
Re: Mtouch Groove87 Spacebar Compatibility
« Reply #1 on: Sun, 16 November 2014, 12:57:35 »
I can't find any info on that keyboard, could you show me a website/storepage so I can do some investigation for you?
Offline edwardpark8
« Reply #2 on: Sun, 16 November 2014, 13:23:09 »
here you go! http://mstonekr.com/front/php/product.php?product_no=204&main_cate_no=1&display_group=2. I've already scanned the page and saw some of the pictures with the spacebar off, but couldn't tell what kind of spacing it was.
« Reply #3 on: Sun, 16 November 2014, 13:33:52 »
OTD says it's got normal stabs, so you can probably use any Filco set with it.
You named the wrong brand which is why I couldn't find anything.
Offline edwardpark8
« Reply #4 on: Sun, 16 November 2014, 13:39:51 »
ah my bad. post edited.
thanks! definitely will be picking up a white one of these over the leopold fc750r then
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Mstone Groove87 Spacebar Compatibility
« Reply #5 on: Wed, 19 November 2014, 13:40:00 »
It's a costar made board, it's almost same as CM Rapid.
