Author Topic: Post your keyboard related autohotkey scripts  (Read 4161 times)
Offline MrFex
« on: Sun, 16 November 2014, 17:45:31 »
Hi -
I've searched these forums for a autohotkey topic that is not specific and only contains a list of autohotkey scripts for keyboard enthusiasts. I've been lurking around and I have found great resources but I haven't found a topic that lists them all. Do you know of such a topic?
Otherwise use this one!
« Last Edit: Mon, 17 November 2014, 15:56:23 by MrFex »
Offline MrFex
Re: Post your keyboard related autohotkey scripts
« Reply #1 on: Sun, 16 November 2014, 17:48:30 »
The following script can be used to adjust screen brightness in Windows (using Gamma, not actual monitor / display driver).
I'm using this on my ducky which has keys for mute, vol up, vol down and calc.
Press CTRL+one of the keys above.
Code: [Select]
; Screendimmer.ahk
; Author    : Appbyfex
; Date      : 2014-11-10
MinValue = -100
MaxValue = 128
Value := 64
Menu, Tray, Icon, Shell32.dll, 44
Menu, Tray, Add, Show Dimmer, ShowWindow
Menu, Tray, Default, Show Dimmer
Menu, Tray, Click, 1
Gui +AlwaysOnTop
Gui, Add, Text, vDim x0 y0, 0`%
Gui, Add, Text, vBright x0 y0, 100`%
Options := "Range-100-128 NoTicks Buddy1Dim Buddy2Bright vMySlider gDimmer"
Gui, Add, Slider, W235 x25 y5 AltSubmit Tooltip Reverse %options% , %Value%
Gui, Add, StatusBar, , Default Brightness 64
Gui, Show, W300 Hide, Screen Brightness
DisplaySetBrightness(Value)
^Volume_Mute::Off()
^Volume_Down::Decrease()
^Volume_Up::Increase()
^Launch_App2::Reset()
Off() {
global Value
Value := -100
UpdateUI()
Reset() {
global Value, MaxValue
Value := MaxValue
UpdateUI()
Decrease() {
   global Value, MinValue
   Value -= 10
  if (Value < MinValue)
    Value := MinValue
UpdateUI()
Increase() {
Global Value, MaxValue
   Value += 10
if (Value > MaxValue)
Value := MaxValue
UpdateUI()
UpdateUI() {
global Value
GuiControl, , MySlider, %Value%
SB_SetText("Brightness level is " . Value)
DisplaySetBrightness( Br=128 ) {
 Loop, % VarSetCapacity( GR,1536 ) / 6
   NumPut( ( n := (Br+128)*(A_Index-1)) > 65535 ? 65535 : n, GR, 2*(A_Index-1), "UShort" )
 DllCall( "RtlMoveMemory", UInt,&GR+512,  UInt,&GR, UInt,512 )
 DllCall( "RtlMoveMemory", UInt,&GR+1024, UInt,&GR, UInt,512 )
 Return DllCall( "SetDeviceGammaRamp", UInt, hDC := DllCall( "GetDC", UInt,0 ), UInt,&GR ),
DllCall( "ReleaseDC", UInt,0, UInt,hDC )
Dimmer:
  DisplaySetBrightness( MySlider )
  Value = MySlider
  SB_SetText("Brightness level is " . %Value%)
Return
ShowWindow:
 DetectHiddenWindows, on
 WinRestore, Screen Brightness
 WinActivate, Screen Brightness
Return
« Last Edit: Mon, 17 November 2014, 15:55:14 by MrFex »
Offline MrFex
« Reply #2 on: Sun, 16 November 2014, 17:51:08 »
The following scripts can be used to move a Window to another monitor.
I'm using this on my ducky which has keys for mute, vol up and vol down.
Press Win+on of the keys above to activate
Code: [Select]
; WindowMover.ahk
; Author    : Appbyfex
; Date      : 2014-11-10
;#NoEnv
;#SingleInstance
Menu, Tray, Icon, ImageRes.dll, 236
; Define monitors
MonitorLeft := 3
MonitorCenter := 1
MonitorRight := 2
; Bind to keys
#Volume_Mute UP::MonitorInfo(MonitorLeft)
#Volume_Down UP::MonitorInfo(MonitorCenter)
#Volume_Up UP::MonitorInfo(MonitorRight)
; Main function that moves the active window
MonitorInfo(Index)
; Get the X, Y, Width and Height of the Active window
WinGetPos, ActWin_X, ActWin_Y, ActWin_W, ActWin_H, A
if !ActWin_W
Return "Error"
SysGet, Monitor, Monitor, %Index%
SysGet, MonitorWorkArea, MonitorWorkArea, %Index%
MonitorWidth := Abs(MonitorWorkAreaRight - MonitorWorkAreaLeft)
MonitorHeight := Abs(MonitorWorkAreaBottom - MonitorWorkAreaTop)
Left := MonitorLeft
Top := MonitorTop
Width := ActWin_W
Height := ActWin_H
if (Width > MonitorWidth)
  Width := MonitorWidth
    else
  Left += (MonitorWidth - Width) / 2
if (Height > MonitorHeight)
  Height := MonitorHeight
    else
  Top += (MonitorHeight - Height) / 2
WinMove, A,, %Left%, %Top%, %Width%, %Height%
« Last Edit: Mon, 17 November 2014, 15:54:30 by MrFex »
Offline Coreda
« Reply #3 on: Sun, 16 November 2014, 18:04:42 »
Nice idea  :thumb: One suggestion: you may want to place the AHK code within [code] tags wrapped in [more] tags so they collapse and can be expanded if wanted. It also provides a neat 'select all' button.
Eg:
Code: [Select]
Example
Offline epzy
  • HHKB Fiend
  • ded
« Reply #4 on: Sun, 16 November 2014, 18:15:06 »
LAlt & w::Send {Up}
LAlt & a::Send {Left}
LAlt & s::Send {Down}
LAlt & d::Send {Right}
Offline MrFex
« Reply #5 on: Mon, 17 November 2014, 15:58:30 »
Thanks for sharing, if you have more please.
Also, what does the code above do? Does that swap single quote with pipe? Why would do you prefer that?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6 on: Mon, 17 November 2014, 16:20:04 »
yeah it simply swaps ' and |
I swap those two because I prefer having ' directly above backspace on my HHKB. it just makes it easier not to miss it
also I set the keyboard language to Norwegian in my OS which makes the layout a bit different
Offline MrFex
« Reply #7 on: Mon, 17 November 2014, 17:19:21 »
Press Win+one of the keys above to activate
Code: [Select]
; WindowMover.ahk
; Author    : Appbyfex
; Date      : 2014-11-10
;#NoEnv
;#SingleInstance
; Define monitors
MonitorLeft := 3
MonitorCenter := 1
MonitorRight := 2
; Bind to keys
MonitorInfo(Index)
if !ActWin_W
Return "Error"
Left := MonitorLeft
Top := MonitorTop
Width := ActWin_W
Height := ActWin_H
    else
    else
