Author Topic: Can the Poker II ABS keycaps be replaced by these translucent PBT ones?  (Read 1428 times)
Offline scott62185
I'm liking the look of a Vortex Poker II keyboard I found but it has ABS keyscaps (looks like the PBT version is sold out?). I found these translucent PBT + POM double shot keycaps http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1003 and I'm wondering if they can replace the caps on the Poker II. (noob here)
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
Re: Can the Poker II ABS keycaps be replaced by these translucent PBT ones?
« Reply #1 on: Mon, 17 November 2014, 11:40:51 »
AFAIK all POKER II are PBT keycap by default
Yes, you can replace the keycap with that PBT+POM ;)
Offline scott62185
« Reply #2 on: Mon, 17 November 2014, 11:44:20 »
Thanks for the reply. But, from what I can tell the only Poker II keyboards available nowadays are the ABS ones (all the PBT versions are out of stock).
  • Live long and prosper
« Reply #3 on: Mon, 17 November 2014, 11:44:38 »
Not all Poker IIs are PBT. The backlit versions are ABS. And I believe some of the non-backlit ones were too, though not 100% sure on that...
tp thread is tp thread
Offline scott62185
« Reply #4 on: Mon, 17 November 2014, 11:47:26 »
Yeah and only the backlit versions are available, as far as I can see...
