Author Topic: SSK has some bad columns  (Read 2079 times)
Offline FrostyToast
  • Litshoard
« on: Mon, 17 November 2014, 14:15:50 »
From this image here, it seems that some of the columns for my SSK are bad... how would I go about fixing this?
EDIT: The keyboard fairies came and gave me some upgrades
« Last Edit: Mon, 17 November 2014, 14:47:42 by FrostyToast »
Quote from: elton5354
Offline E TwentyNine
    • Some of My Keyboards
Re: SSK has some bad columns
« Reply #1 on: Mon, 17 November 2014, 14:36:33 »
First thing I'd do is open it up and reseat the connectors in the controller.
If I had another M with that style controller board (SSK or not) I'd switch boards and see what I get.
Offline FrostyToast
  • Litshoard
« Reply #2 on: Mon, 17 November 2014, 14:38:02 »
The first problem is opening it up.... I'm going to need a sturdy pen and something to melt it with...
Offline FrostyToast
  • Litshoard
« Reply #3 on: Mon, 17 November 2014, 14:43:17 »
Also, after I open it up, how would one reset the connectors?
Offline FrostyToast
  • Litshoard
« Reply #4 on: Mon, 17 November 2014, 14:48:33 »
Strange update in the OP
« Reply #5 on: Mon, 17 November 2014, 15:19:44 »
Get the file here: https://geekhack.org/index.php?topic=34670.msg641440#msg641440
Run it and take a screenshot.
Offline FrostyToast
  • Litshoard
« Reply #6 on: Mon, 17 November 2014, 15:27:49 »
These are the newest results... it seems that the some of the keys have reverted to being bad for some reason.
EDIT: and now I get this
« Last Edit: Mon, 17 November 2014, 15:30:04 by FrostyToast »
« Reply #7 on: Mon, 17 November 2014, 15:44:03 »
It does make sense.  The PgUp/PgDn are the only keys on that trace on an SSK, and F2-F4 shares the column with 3 down.
The connector I'm talking about is the ribbon connectors that go into the controller board.  If you're getting mixed results like this that would lead me to believe the connector there is dirty/corroded and it's getting intermittent contact.   Reseating them may do the trick. If it doesn't,  a *GENTLE* cleaning with a damp cloth of the ribbon connectors may help as well.   Clean them in the direction of the trace, not across all of them at once.
Offline FrostyToast
  • Litshoard
« Reply #8 on: Mon, 17 November 2014, 15:45:43 »
Cool! I will try that if I ever get a tool (or melted pen) to unscrew the thing
