Author Topic: clear and blank?  (Read 2983 times)
Offline FinancialWar
clear and blank?
« on: Tue, 18 November 2014, 05:55:33 »
Are there any 100% transparent/clear and blank key caps on the market?
Offline Oobly
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Re: clear and blank?
« Reply #2 on: Tue, 18 November 2014, 06:57:28 »
Will these fit Filco 104?
Offline jinq-sea
« Reply #3 on: Tue, 18 November 2014, 08:33:08 »
Yep!
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #4 on: Tue, 18 November 2014, 08:35:06 »
I want to know how they made that spacebar fit on that CM TK, I have a TK and I have SP space bars, and the SP space bars do not fit on my TK :(
I got boards.
Offline Oobly
« Reply #5 on: Tue, 18 November 2014, 08:40:12 »
"Full sets include all keycaps for a standard 104 ANSI layout"
So if your Filco 104 is standard layout (which it is), then yes...  The extra 13 key set is for other layouts like WinKeyless, etc.
Offline Oobly
« Reply #6 on: Tue, 18 November 2014, 08:42:32 »
They didn't... They stuffed a standard 6.25x spacebar onto the spacebar switch without the stabilisers installed. You can see the stabilisers don't line up with the stem mounts. No idea why they'd use a TK for the product shots, since it doesn't actually fit on one.
  • Dungeon Dweller
  • Get back to work!
« Reply #7 on: Tue, 18 November 2014, 10:07:52 »
I thought I could see that, thanks for the confirmation :)
It's keen marketing that's what it is.
I got boards.
« Reply #8 on: Tue, 18 November 2014, 13:15:19 »
On the red and blue pictures you can also see a fair sized gap between space and Alt on each side.
Offline berserkfan
« Reply #9 on: Mon, 24 November 2014, 21:37:11 »
You can try the following:
banggood
max keyboard
x-keys (relegendables; they work real well too)
Offline 0100010
  • Not Sure
« Reply #10 on: Fri, 28 November 2014, 21:11:04 »
Thanks Gutz for the xkeys suggestion - much cheaper option there compared to SP; relegendable too).
Offline berserkfan
« Reply #11 on: Sat, 29 November 2014, 02:32:10 »
If I find something I like I always talk about it.
In fact if you want to see how xkeys look in real life just look at my keycaps emporium thread, since I had xkeys that I stuck printed paper inside and taped to a board to mark out the rows and columns!
