Author Topic: Ducky Shine 4- Does the space bar still have RGB?  (Read 5225 times)
Offline dman777
« on: Tue, 18 November 2014, 13:10:26 »
Ducky Shine 4- Does the space bar still have RGB? Also, strange there aren't alot of posts on here on the Ducky's latest Shine iteration(other than the main massive thread).
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
Re: Ducky Shine 4- Does the space bar still have RGB?
« Reply #1 on: Tue, 18 November 2014, 13:32:03 »
No RGB Led on the spacebar sir ;)
Offline faceyourfaces
« Reply #2 on: Tue, 18 November 2014, 18:22:47 »
I've been wondering where all the Shine 4 posts have been. Whatever, I'm still bitter about Ducky anyway.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #3 on: Tue, 18 November 2014, 18:41:39 »
Really? Wow, I thought they would leave it there lol.
Offline xxsoulxx
« Reply #4 on: Sat, 17 January 2015, 08:21:14 »
What a fxxxing shame ducky i just got my Shine 4 for my collection, just noticed it. Thicker bezel just e few colors an now even this...
Offline Dihedral
  • Mostly Harmless
« Reply #5 on: Sat, 17 January 2015, 08:49:18 »
What is the difference between MX RGB and this?
« Reply #6 on: Sat, 17 January 2015, 08:52:07 »
Not sure what you are referring to. In the previous Ducky Shine 3 the spacebar area had customizable color lighting options for that particular switch separate from the rest of the keyboard the Shine 4 does not. This has nothing to do with MX RGB.
Shine 3 spacebar
« Last Edit: Sat, 17 January 2015, 08:54:22 by SpAmRaY »
Offline Dihedral
  • Mostly Harmless
« Reply #7 on: Sat, 17 January 2015, 08:54:23 »
Sorry, it's off topic, but I'm struggling to see the difference between Cherry MX RGB and manufacturer implementations of RGB backlighting with MX Switches like this ducky.
« Reply #8 on: Sat, 17 January 2015, 08:58:15 »
Again see photo I edited in above, the shine 3 had 3 separate led's in the spacebar area to make different color options by combining the 3 colors.
 The cherry mx RGB clear case switches as implemented by corsair use rgb smd leds on the PCB to enable multiple colors theoretically for each switch depending on software implementation. The point of the cherry mx rgb switches is that they have a clear case and the led is no longer in the switch but on the pcb and can be illuminated and diffused by the entire switch casing.
The ducky shine 4 fire edition has a few different dual color led's but that is also different again.
Offline Dihedral
  • Mostly Harmless
« Reply #9 on: Sat, 17 January 2015, 09:05:59 »
Ah, OK. So the main difference is the clear case. Makes sense.
« Reply #10 on: Sat, 17 January 2015, 09:11:53 »
A clear case that is designed to fit an RGB SMD between it and the PCB.
Offline Dihedral
  • Mostly Harmless
« Reply #11 on: Sat, 17 January 2015, 09:14:28 »
snip
Great. I appreciate the help.
