Author Topic: Model F porn.  (Read 86840 times)
Offline ch_123
Model F porn.
« on: Tue, 21 July 2009, 18:33:47 »
Okay, as suggested by Ripster, I moved all these pics over here to their own article, and even took a few more for good measure. Here is the inside of my PC/AT Model F. I won't bother going through disassembly instructions, as Chloe's guide is more detailed than anything I'd be able to give. The only thing I'd point out is that you don't really need clamps, you can detach and reattach the two plates by pushing one end of the assembly into your floor at an angle, while pushing hard on the other end. Also, Chloe's article mentions something about needing to remove a screw before seperating the plates, but I think this is specific to the XT model.
Here's the keyboard in it's fully assembled state, front and back. In contrast to the verbose Model M labels, all you get is the serial number and the bar-code. (although Greenock-made ones have more detailed labels which sometimes include a manufacturing date) You can also see the feet which are spring loaded and adjusted by the two knobs on either side of the board. A million miles away from the rubber dome Dells in the computer lab in my college whose feet snap off at random, leaving the keyboard lopsided.
][/URL]
The inside of the front and back of the casing. Between the two of them, they weigh more than your average rubber dome board. The interior has a rough texture to it, as if it were made of really really fine sandpaper.
A common complaint when opening up the back is that you get a creaky noise and feeling, and many get the impression that it's about to break or snap. This is normal, a hard yank will separate the two sides.
 Oh, and don't ask me what that white stain is - it was there when I got it, and I'd rather not think about it :P
The up-side of the assembly. You can see that the metal plate is actually painted a dark olive colour, not black. However, it catches the light and is quite shiny. It's apparent from the where the flash of the camera shines on the board, but you can see the shine between the keycaps when using the keyboard in a well lit room. A particularly good example is this picture.
The underside of the assembly with it's 'Model F' badge. I thought from the 'shop Date' code that my keyboard was made in 1987, but I have seen shop dates from similar boards that look completely meaningless, so I guess it's just some random numbers that only IBM understands. Also note the lack of plastic rivets - the two sides slot together.
The underside of the front plate, which is in a bit of mess with all the spring/hammers either upside-down or turned to their side. There's a layer of (extra crumbly) foam covered with what looks and feels like a thin layer of fake leather attached to the underside. You can also see the infamous stabilizer bar which can only be hooked into the spacebar when the whole thing is disassembled, and the latches which hook the bottom plate to the top. As you can see that from the two missing ones beside the space bar, the barrels are easily removed, in fact, nothing is holding them in place except for the back plate (when it's attached) which means that the whole thing falls apart when you open it up. You also have to be careful when reassembling it to ensure the springs don't fall out and get squashed.
Here's the PCB mounted on the lower plate. It appears to have two layers to it. The PCB is covered in a protective layer which ensures that the hammers never make direct contact with the switches beneath them. Each switch consists of two plates, and when you press a key, it causes a hammer to lie across the two and change their capacitance, which is picked up by the keyboard and registered as a key press. What's interesting is that some of the terminals are unusued, and therefore it could be possible to 'hack' the keyboard into a more standard ANSI or even an ISO layout. (EDIT: 'JohnElliot' has confirmed that this is possible. The unused contacts send out unmapped scancodes that could be mapped to the missing keys...)
A zoom up of the controller board. The large Intel chip is the controller, the black one beside it is a Hex Invertor, and the silver unit to the other side is more than likely the oscillator, which is needed for a capactive keyboard to work (see the Perfect Keyboard Controller thread). Most of the pins on the Berg connector are unused. Only the five topmost and five bottommost are used - for the LED panel and AT cable respectively.
Finally, a picture of what you see when you open the back of the keyboard when it's properly connected together. You can see that the black grounding cable from the controller placed on top of one of the screw holes in the casing, with a similar wire from the AT cable placed on top, and fastened together with a screw. Also of note is that the whole assembly is only secured with two screws (although the bottom of the assembly slots into little tabs that you can see at the bottom of the picture). I'm not sure if the XT's assembly was secured any better, but if I were designing it, I'd have it secured with at least four screws, especially considering that the key assembly alone weighs nearly 2.5KG
Thought I'd throw this in here - When I reassembled it after opening it up for the first time, I decided to check it out before I put the keyboard assembly back into the casing. I hooked up the cable into my laptop and opened a text editor. I press some keys and nothing happened. A second later, the keyboard started sending loads of random keypresses to the computer, causing the text editor to be filled with letters and numbers, and menus on the software to be opened. Figuring that I hadn't assembled it properly, I opened it up, and re did all my earlier work (a rather grueling task considering that when you take the the assembly apart, all the springs and barrels inevitably fall out, requiring you to remove all the keycaps, put all the barrels in, put all the springs in and then later put all the keycaps back in) and put it back together again. Same result. So, I tried again, and then again... The same result each time.
I had pretty much given up on getting it to work again, so I put it up on the desk and went to unplug it, when I noticed that it stopped sending the random keypresses. I typed on it, and it worked perfectly. I put it back on my lap and it started going off again. Suddenly it hit me - it was because I was wearing shorts. When I had it on my lap, the underside of the controller board was resting against my exposed knee, where the skin was causing it to short out and act as if all the keys were being pressed at the same time...
The irony was, that if I had never bothered "testing" to make sure it was ok, I never would have experienced the problem.
« Last Edit: Sat, 14 November 2009, 13:58:24 by ch_123 »
Offline JBert
Model F porn.
« Reply #1 on: Wed, 22 July 2009, 12:38:49 »
In the Model F XT the backplate is made of metal and has a few cutouts at the bottom to grab the latches on the keyboard assembly so the internals won't move. Other than that, no screws are used to attach the keyboard assembly to the plastic front of the case - the 2 screws in the case's backplate keep everything together.
I wonder what the weight of the XT is with the extra metal plate... I can't check it for now.
EDIT: Take a look at a sample from clickykeyboards (the last picture):
http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/11066/subcatid/0/id/350492
« Last Edit: Wed, 22 July 2009, 12:42:35 by JBert »
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline ch_123
Model F porn.
« Reply #2 on: Wed, 22 July 2009, 12:59:36 »
It's reasonably uniform, but there is notable difference on certain keys. Things like wear and the fact that it's been disassembled a few times could explain that though.
@Jbert: Mhmm, that's interesting to know. So do those screws hold the assembly against the back of the case?
I have to get me an XT Model F one of these days, and a terminal one too xD
« Last Edit: Wed, 22 July 2009, 13:02:34 by ch_123 »
Offline JBert
Model F porn.
« Reply #3 on: Wed, 22 July 2009, 15:32:53 »
Quote from: ch_123;103811
No, the only thing they do is squish the whole thing together. Take another look at Chloe's pictures of the XT:
http://s727.photobucket.com/albums/ww280/switch-kitten/ibm%20pc%20xt/DSCN6074.jpg
http://s727.photobucket.com/albums/ww280/switch-kitten/ibm%20pc%20xt/DSCN6132.jpg
You can see the notches on which the assembly rests, the case's backplate makes sure it can't get out of there.
Other differences include the controller board: it's not seperate but it sits on the keyboard PCB.
As you know, not much use having one until you get yourself an adapter. It does make a superb (and clicky) paperweight...
The storage list:
[/SIZE]
Offline ch_123
Model F porn.
« Reply #4 on: Wed, 22 July 2009, 15:42:40 »
Well, my usual paperweights have been rather mushy as of late :p
Offline ch_123
Model F porn.
« Reply #5 on: Wed, 22 July 2009, 16:27:01 »
What do the Model M2s feel like compared with the F and the regular M?
Offline Hak Foo
  • Make America Clicky Again!
Model F porn.
« Reply #6 on: Wed, 22 July 2009, 23:50:06 »
If it weren't for the quality issues, I could see the M2 as a better alternative for the "small keyboard" design... it's frankly slick in a way the EnduraPro design isn't.
Overton130, Box Pale Blues.
Offline ch_123
Model F porn.
« Reply #7 on: Thu, 23 July 2009, 07:15:54 »
Quote from: ripster;103888
So does the Unicomp.  The M2 might be the "missing link" between the two.
Nah, I think the Unicomp Customizers are just a copy of the 42H.
How do you mean that they sound better than the Model M? I've only ever used a rather worn out M so I couldnt really tell the difference sound wise.
Offline Mercen_505
Model F porn.
« Reply #8 on: Thu, 23 July 2009, 08:39:36 »
I have only typed on one for a day, but I started to think: same as M, but feels different nevertheless because of the different shaped keycaps (which are worse than an ordinary M). It sounds better than an M.
I love the sound of the M2, but it takes me some time to adjust to since the board isn't 'scooped' like an M. My fingers are expecting that subtle curve, and since it's not there... it's just a little odd. I'm seriously thinking of swapping the guts of my working M-2 into a non-functional M2. That way I can have a semi-quiet keyboard with the smaller footprint for use at work.
Offline msiegel
Model F porn.
« Reply #9 on: Sat, 19 September 2009, 15:28:19 »
correct me if i'm wrong, but on the model f's switch pcb... are the pads for the main block in the right places to:
rows 1-3: reproduce the hhkb layout
rows 4,5: reproduce the model m layout
http://img229.imageshack.us/i/img3329.jpg/
Offline ch_123
Model F porn.
« Reply #10 on: Sat, 19 September 2009, 17:58:21 »
Definitely for the Model M (and some people have got the unused contacts working) and yes for the HHKB if you're willing to accept widely seperated keys on the bottom row.
Offline msiegel
Model F porn.
« Reply #11 on: Sat, 19 September 2009, 21:19:22 »
Quote from: ch_123;119307
interesting :D
i'm thinking of how few switch assemblies would need new holes in the mounting plate, in order to produce a usable main-block-only keyboard
ch_123, do you think the model m's rubber mat dampens spring vibrations?
Offline JBert
Model F porn.
« Reply #12 on: Sat, 24 October 2009, 07:23:26 »
Hmmm, I wanted to take a look at this topic again to see if there were any tips on how to get the back cover seperated from the front.
Seems ImageShack caught wind of this topic as the pictures now show a "domain has been banned due to porn/topsite/..." placeholder. Please find another image provider or get this domain unbanned.
The storage list:
[/SIZE]
Offline ch_123
Model F porn.
« Reply #13 on: Sat, 24 October 2009, 09:41:36 »
I can see them fine here. Can anyone else see them?
Offline JBert
Model F porn.
« Reply #14 on: Sat, 24 October 2009, 10:21:50 »
Strange, they used to show an ImageShack placeholder. Probably iMav fixed it in the man time.
I'll take a screenshot next time it happens.
The storage list:
[/SIZE]
