Author Topic: G80-3000 Advice  (Read 1887 times)
Offline Naes
G80-3000 Advice
« on: Tue, 18 November 2014, 17:48:46 »
I've had my cherry g80 with blues for about 4 months now and I'm loving it. However I have noticed that it lacks a metal plate and it seems to give ever so slightly when I'm typing on it. I'm just curious as to how I would go about getting some form of reinforcement for it. I have tried a strong, flat piece of plastic under the pcb but this just caused the pcb to rattle and tilt whilst typing and made the blues even louder.
Thanks for any help. Also; first post p-plz be gentle geekhack-senpai
Also also; any mods or cool **** I can do with this keyboard? I haven't had a project for ages.
« Last Edit: Tue, 18 November 2014, 17:51:45 by Naes »
Offline FrostyToast
  • Litshoard
Re: G80-3000 Advice
« Reply #1 on: Tue, 18 November 2014, 18:02:17 »
You could try using some pond liner under the PCB.
This mod is usually meant to reduce the resonance of sound and make your board quieter, but I guess it could also work for this as well.
Quote from: elton5354
Offline Naes
Re: G80-3000 Advice
« Reply #2 on: Tue, 18 November 2014, 18:12:04 »
Thanks, I'll probably try that cause I've got some pond liner out the back, so that's a free option.
Offline Naes
Re: G80-3000 Advice
« Reply #3 on: Wed, 19 November 2014, 10:50:56 »
Tried this out. It works quite well, the noise of the blues is much less noticeable now. My family may be able to sleep undisturbed by the clackyclack. Thanks!
Offline Oobly
Re: G80-3000 Advice
« Reply #4 on: Wed, 19 November 2014, 13:39:08 »
You could also put some stronger support under the pond liner to improve the feel. The newer G80-3000 boards have very flexible PCB's and can certainly do with some support.
In terms of mods, have you considered opening the switches and swapping out the stems and springs to make some 62g ErgoClears? They're my favourite MX switches, just a little stronger than Blues, but very tactile and quieter. Being a PCB mount board you don't have to desolder anything to do switch mods :)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline inlikeflynn
  • file not found
Re: G80-3000 Advice
« Reply #5 on: Wed, 19 November 2014, 14:05:38 »
do this: https://geekhack.org/index.php?topic=13165.0
short of having a real plate ontop of the PCB, this is the next best thing for any of the g80 boards to make them stiffer and heavier
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
