Author Topic: 2TU firmware  (Read 1240 times)
Offline evolveS
  • ಠ_ಠ
2TU firmware
« on: Fri, 21 November 2014, 09:04:09 »
This might be a long shot, but have any 2TU owners been able to flash new firmware to the ATMEGA32U on these boards? If so, what software did you use to do it?
I'd like to update my Fn layers.
"money comes and goes, but doubleshots are forever"
-a petty thief
Re: 2TU firmware
« Reply #1 on: Fri, 21 November 2014, 09:11:37 »
Offline evolveS
  • ಠ_ಠ
Re: 2TU firmware
« Reply #2 on: Fri, 21 November 2014, 09:21:34 »
Thanks cpt, it does! I've never used a USB ISP before so I'm curious about how that would go down. It doesn't seem that straightforward which one I should buy either.
More to the point, the polling rate on my 2TU is way too high for me. I'll have to try the software later and see if I can change that.
« Last Edit: Fri, 21 November 2014, 11:56:19 by evolveS »
-a petty thief
