Author Topic: Tactile non-clicky keyboard.  (Read 5692 times)
Offline mougrim
« on: Fri, 21 November 2014, 12:40:41 »
I love my AT Model F - but now I need something quiet for working at nights (I was threatened by my family - they say they'll kill me, and if you heard typing on any IBM keyboard, you know they MEAN it)
So... There are Code keyboard with MX Clears on Massdrop now. Will it be suital for my purpose?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline Flyersfan1
  • Hi!
Re: Tactile non-clicky keyboard.
« Reply #1 on: Fri, 21 November 2014, 12:44:31 »
Clears sound like they would be perfect for you! They are very tactile and are relatively quiet too!
Quote from: Photekq
Offline saturnotaku
« Reply #2 on: Fri, 21 November 2014, 13:39:49 »
Something with Cherry MX clear or a Realforce 87U 55g (Topre switch) would be suitable. Most of the noise from Cherry switches comes from bottoming out, which you can mitigate by adding o-rings to the stems on the keycaps.
Topre switches are definitely quieter, but their noise can be reduced through the addition of thin dental bands and/or lubing the stems.
Offline mougrim
« Reply #3 on: Fri, 21 November 2014, 14:04:59 »
Thankee for advice :) I'll think about it.
Offline jacobolus
« Reply #4 on: Fri, 21 November 2014, 15:20:31 »
I recommend Matias quiet switches over MX or Topre, if you’re looking for something with snappy action and quiet.
Offline spiceBar
    • ChessTiger.com
« Reply #5 on: Fri, 21 November 2014, 23:24:38 »
Yes. I am now the proud owner of a Matias laptop pro (compact Bluetooth), and I have been pleasantly surprised by the Matias quiet switches.
@OP: Cherry MX browns or clears, Topre or Matias quiet switches based keyboards seem to be what you are looking for. That gives you plenty of choices.
Offline JDorfler
    • My Blog
« Reply #6 on: Fri, 21 November 2014, 23:27:35 »
Would you say the Cherry Browns and Clears are very related in feel?  If so, what would be the difference?
Offline saint_james
« Reply #7 on: Fri, 21 November 2014, 23:41:00 »
Both are non-clicky tactile.  However, the tactile bump is much more pronounced with clears... at times I can barely feel the bump on browns... and of course, clears are a noticeably heavier switch.
C = Q/V ≈ ε₀ (A/d)
Active: FC980C | FC660C Low-noise | RF 87u 55g | RF 23u
Inactive: WASD v2 | Pok3r | QFR | Aukey KM-G9 | Compaq RT101
Dead and buried: Microsoft Natural Keyboard Elite
Offline JDorfler
    • My Blog
« Reply #8 on: Fri, 21 November 2014, 23:43:01 »
Thank you.
Offline spiceBar
    • ChessTiger.com
« Reply #9 on: Fri, 21 November 2014, 23:46:26 »
Yes, they are very related in feel.
The tactile bump in browns is subtle. Less noticeable than on a rubber dome keyboard. You notice it only of you have a "light" typing style and do not bottom out hard.
In clears, the bump is much more noticeable. The spring is also stronger (~38% stronger), so with the same force you are less likely to bottom out hard on Cherry MX clears.
Some people say that clears are what browns were designed to be, and would never go back to browns.
Other people say that clears are too stiff and after trying clears they go back to browns.
It all depends on your typing style, or your ability to adapt your style to a new switch.
Offline mougrim
« Reply #10 on: Sat, 22 November 2014, 03:28:52 »
Matias... Well, I keen to try it, but keycaps... Let's say, you pretty much limited to stock ones. And I have this nice new Granite keyset sitt ;)
I doubt clears will be too stiff for me. Because, buckling spring :)
Offline kaiteoki
« Reply #11 on: Sat, 22 November 2014, 03:35:00 »
Go wit topre
Offline berserkfan
« Reply #12 on: Sat, 22 November 2014, 06:29:06 »
mougrim my friend
let me take advantage of the moment to introduce my favorite switch type... the jailhouse blues. It is truly tactile and ultra quiet. It's the quietest Cherry switch you'll ever have. And tactile as clears too!
As long as you are willing to put the time in to produce the jailhouse effect.
I do recommend that you be using a PCB mounted keyboard or a board with switch moddable plate, because sometimes you need to adjust the switch based on my method. But my method is quick and painless and I'm proud of it. (Not going to publicize to geekhack at large until I have convinced a few friends to try and they are equally satisfied after some time of real usage.)
I'll send you what you need for a six buck donation to Dorkvader's Hall Effect project. You can always do the mod while hiding under your F AT in your bomb shelter when Putin's Platoons storm in.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #13 on: Sat, 22 November 2014, 09:58:24 »
Dell Quiet Key RT7D5JTW
Save yourself a bunch of money.........some people compare pressure to Topre
It is a slider over rubber dome- tactile and quiet
http://www.ebay.com/itm/NEW-DELL-QUITEKEY-KEYBOARD-RT7D5JTW-/170933972759?pt=PCA_Mice_Trackballs&hash=item27cc756f17
I spruced mine up a little because I was bored..........
« Last Edit: Sat, 22 November 2014, 10:03:20 by terrpn »
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline vivalarevolución
« Reply #14 on: Sat, 22 November 2014, 10:19:27 »
I echo this sentiment, although MX Clears with 65g springs and thick metal plate underneath it are not too bad.  But it won't be cheap to all those elements together, that's for sure.
Offline Oobly
« Reply #15 on: Sat, 22 November 2014, 15:30:40 »
I recommend MX Clears with orings (or trampoline mod if you're willing and able to desolder the switches to open them). They're quiet, very tactile and have a nice spring profile. And of course you have a large range of keycap sets that fit.
Topre switches are quiet, too, but even the 55g ones may seem a bit "weak" if you're used to Model F springs. At least Model F are lighter than Model M :)
Personal favourite switch is 62g ErgoClears with trampoline mod. If you're going to open the switches I highly recommend trying this combination. The 62g spring increases the tactility while decreasing the force required and the trampolines dampen the bottom out.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #16 on: Sat, 22 November 2014, 15:58:21 »
KUL ES-87 with clears, my favorite board.
Offline elecplus
    • Electronics Plus
« Reply #17 on: Sat, 22 November 2014, 18:11:16 »
Since when do u have time to get bored, terrpn?
Offline 0100010
  • Not Sure
« Reply #18 on: Sat, 22 November 2014, 19:06:03 »
I am used to buckling springs myself, and after finding that even the heaviest Cherry switches are not as strong as buckling springs; I would say go for Cherry MX Light Greys (tactile).  But a stock board with MX Clears would probably be easier to get a hold of.
Offline jacobolus
« Reply #19 on: Sat, 22 November 2014, 19:35:19 »
For someone who likes a Model F, MX clear is going to be tiring to type on.
Offline mougrim
« Reply #20 on: Mon, 24 November 2014, 03:12:13 »
Yep, even Greens are too light for me now :)
First I need to get hold of some board with Clears... then I'll think ;)
Offline berserkfan
« Reply #21 on: Mon, 24 November 2014, 06:24:49 »
WE can talk over PM. Am interested in having a new guinea pig for my jailhouse blues. And I should have one or two clears and tactile grays I can send you, again for the price of a donation to the main project I am supporting now.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #22 on: Mon, 24 November 2014, 10:43:25 »
What about Greys?
Offline mougrim
« Reply #23 on: Mon, 24 November 2014, 11:08:26 »
What about Greys?
They're pretty much unobtanium, if we're talking about mass-produced boards ;) Or not?
Offline katushkin
  • Just the guy
« Reply #24 on: Mon, 24 November 2014, 11:15:12 »
What about Greys?
You could buy a load from mechanicalkeyboards.com and get someone to desolder old switches and resolder on the greys? Clears are getting easier to come by but they aren't massively available, and I've seen greens available on about 3 boards in the last 6 months.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #25 on: Mon, 24 November 2014, 11:41:25 »
I have a Code with Clears. I also have a IBM SSK, but sadly no F. I'm typing on the SSK right now and I have the CODE sitting right in front of me. The CODE is much quieter than my SSK, but it certainly isn't what I would call "quiet" either. I see people say that Clears are considered a quite switch, and maybe that is true, but it isn't the case on my CODE. I don't have any other experience with clear switches to compare it against. In my case the noise isn't really a problem, but if you are aiming for quite, this CODE I have sure doesn't fit that bill.
Offline mougrim
« Reply #26 on: Mon, 24 November 2014, 11:55:27 »
Hmm... I kinda tempted about Novatouch... But I think it will be too light and too un-tactile.
Maybe later. When they'll release V2. With 55g domes :)
Offline mougrim
« Reply #27 on: Mon, 24 November 2014, 16:45:52 »
