Author Topic: [GB] 1976 - Flashback to the Colors of the 70's (SA Row 3) --- Shipped  (Read 280944 times)
Offline engicoder
Re: [IC] 1976 - Flashback to the Colors of the 70's
« Reply #100 on: Wed, 26 November 2014, 23:19:31 »
Specialty kit should also have a 1x backspace. That's my only real nitpick.
Have we decided on SA vs DSA yet? I could probably tolerate DSA more than SA if it helps. In fact, let's get a poll going.
Not a problem....will add the 1x Backspace.
SA. It's more in keeping with the 70's aspect of the set. Furthermore, after holding the Nuclear Data Green set in my hands, I believe the semi-matte finish will be more fitting for this set.
Offline Data
« Reply #101 on: Thu, 27 November 2014, 00:22:17 »
I came up with a preliminary group of sets. Let me know what you guys think. What am I missing?
Loving it.  I'm in for a base set, alt gradient, and specialty kit at minimum.
You mentioned doing it in all Row 3 SA at one point.  Is that still the plan?
Offline engicoder
« Reply #102 on: Thu, 27 November 2014, 00:34:09 »
Yes....  suppose I should specify that somewhere
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #103 on: Thu, 27 November 2014, 10:32:39 »
Looking awesome...  Can we add a blue 1976 1.25 key to the Alternate kit so we can have symmetry on both sides?
I am loving this set.  If you make it in Row3 SA that will make it one of the most epic sets around...  Can we get deep dish homing keys as well?  It makes a pretty big difference IMO.
This is looking sooo good...  :)
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: [IC] 1976 - Flashback to the Colors of the 70's (SA Row 3)
« Reply #104 on: Thu, 27 November 2014, 12:18:47 »
I think the base set should be 60% only... make nav+function row an add on kit. Yeah I want to be a CHEAPSKATE! I liked the individual 1 9 7 6 keys from earlier. F4 should be red really.
Offline unoab
« Reply #105 on: Thu, 27 November 2014, 12:26:17 »
Looks awesome, I would be in for a TKL set.  And I am with Ivan, an alternate F4 that is red/dark orange just looks right as opposed to the blue one.
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #106 on: Thu, 27 November 2014, 12:28:07 »
SA and you couldnt take my money fast enough
Offline engicoder
« Reply #107 on: Thu, 27 November 2014, 13:18:37 »
Ooops, another oversight. Thanks!
« Last Edit: Thu, 27 November 2014, 13:54:54 by engicoder »
Offline engicoder
« Reply #108 on: Thu, 27 November 2014, 13:21:04 »
I thought about this. Need to ask SP if there is a price differential (i.e a set with N keys vs the same set broken into two sets).
Yes, on the F4. I omitted it as I was patterning the set after the original artwork in which the red and orange reach the bottom and the yellow reached the top. I understand where you guys are coming from, so adding it as an extra makes sense.
The "1 9 7 6" set could be an option.
« Last Edit: Thu, 27 November 2014, 13:23:19 by engicoder »
Offline engicoder
« Reply #109 on: Thu, 27 November 2014, 16:31:56 »
  I moved the images of the sets to the OP to avoid confusion from reposting the image as it changes or having it buried in the post pages.
Offline jackalope
  • Now with 20% more soul.
« Reply #110 on: Thu, 27 November 2014, 22:17:51 »
 It seems that I want this set more and more with each mockup. In for base set , primary and alternative gradient kit, slang kit and color kit.
« Last Edit: Fri, 28 November 2014, 17:12:48 by jackalope »
eh o well
Offline engicoder
« Reply #111 on: Thu, 27 November 2014, 22:52:59 »
Curious if their could be a groovy or maybe funkadelic enter key.
Why not. adds a bit of levity. How about "Dyn-o-mite" or "The Man" or "Ten-Four"?
« Reply #112 on: Fri, 28 November 2014, 03:22:07 »
Really like how this is looking, I assume it will be offered with blanks?
Offline Oobly
« Reply #113 on: Fri, 28 November 2014, 07:45:54 »
It seems that I want this set more and more with each mockup. In for base set , primary and alternative gradient kit.
Yeah, and where's the "DISCO" key!? :D I can hear the BeeGees playing in my mind...
I'm not sure it's worth offering the reverse diagonal numpad option, but maybe with a low MOQ on that item it could work as it is in the OP now, but with the addition of the red F4 key as an extra in the base kit :) I'm also not sure about the alternate stripe kit, I think it will also end up having a lot less orders than the main stripe, but again, could work as a low MOQ, higher initial cost kit.
Great that there are deep dish homing keys and Colemak and Dvorak kits :)
Can you dig it? That engicoder cat is far out! Gonna get down and boogie with this set. It's all hip in this gig. Keep on truckin'. Oh yeah, slip me some skin. <"you should be daaancin' - yeah">
-EDIT: Do you think Isotherm font or the standard modified Gorton would be best for this? Is Isotherm groovy or just too modern / scifi-ish? www.keycapsdirect.com/pdfs/LineFont.pdf
« Last Edit: Fri, 28 November 2014, 07:49:05 by Oobly »
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Data
« Reply #114 on: Fri, 28 November 2014, 07:56:10 »
In honor of Thanksgiving: "Jive Turkey"
Offline Oobly
« Reply #115 on: Fri, 28 November 2014, 08:09:17 »
May I suggest "GET REAL" for the enter key, "SPLIT" for Esc, "BUMMER" for Backspace and "BOOGIE" for Shift or is that too whimsical?
Offline JPG
  • Model F is my new passion!
« Reply #116 on: Fri, 28 November 2014, 08:12:43 »
Just saw this. It looks totally awesome. By far the best I've seen in a long time. I am almost sad that I don't use mx anymore, but my wallet is quite happy!
Offline engicoder
« Reply #117 on: Fri, 28 November 2014, 08:37:43 »
Yes...blanks of all 5 colors.
Offline engicoder
« Reply #118 on: Fri, 28 November 2014, 08:44:43 »
I am trying to make this set as flexible as possible. Its not like most two tone kits with mods and alphas, so for now lets let things ride. If we run this through PMK, some sets might not tip but that will be decided by the buyers.  If we do it the old fashioned way, yes, MOQ will have to be considered.
Probably go with Gorton as it would have been closer to fonts used on keyboards at that time.
« Last Edit: Fri, 28 November 2014, 11:59:15 by engicoder »
« Reply #119 on: Fri, 28 November 2014, 10:38:43 »
If we're gonna be offering a lot of kits, it's probably better to run this through PMK.
Offline engicoder
« Reply #120 on: Fri, 28 November 2014, 12:18:06 »
Nice suggestions...they all work pretty well. I will have to coalesce the various work suggestions into a mockup and see people prefer.
Offline GankIndustries
« Reply #121 on: Fri, 28 November 2014, 12:48:46 »
I nominate "JIVE TURKEY" for the enter key.
Poker 2 Clears
V2 Reds
60% Alps loading
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #122 on: Fri, 28 November 2014, 12:53:04 »
Any thought to incorporating Avocado in the color mix? I know it wouldn't go with the blue, but maybe in lieu of the blue
« Last Edit: Fri, 28 November 2014, 13:18:08 by 00zeRO »
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
« Reply #123 on: Fri, 28 November 2014, 13:16:24 »
Considering we're basing this set off of an image, I'm not big up on that idea.
On another note, how about a cyan enter key? That shouldn't be too expensive. Maybe even a whole set of all 4 colors?
Offline 00zeRO
« Reply #124 on: Fri, 28 November 2014, 13:18:52 »
Duly noted, and stricken out.
« Reply #125 on: Fri, 28 November 2014, 16:39:57 »
Sweet, I'm definitely in!
Offline engicoder
« Reply #126 on: Fri, 28 November 2014, 17:10:01 »
OP updated with Color and Slang Kits. Please give me feedback on Slang Kit. What's good, what's lame and what's missing?
« Reply #127 on: Fri, 28 November 2014, 18:38:37 »
No righteous?
Offline engicoder
« Reply #128 on: Fri, 28 November 2014, 18:43:04 »
No righteous?
That's a long word....what key would you put that on? Right Shift seems like the obvious choice  ;D
« Reply #129 on: Fri, 28 November 2014, 18:52:43 »
No righteous?
yessir right shift is righteous
Offline engicoder
« Reply #130 on: Fri, 28 November 2014, 18:57:44 »
Offline longcat
« Reply #131 on: Fri, 28 November 2014, 20:12:22 »
I'm in on this as well! This set will be sweet in SA's.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #132 on: Fri, 28 November 2014, 21:01:02 »
Added
In the slang kit you should add one at 1.75 units long so it can be used as a short right shift if anyone wants to use this on a Pure layout.
This set is looking great btw.  Good work...
« Reply #133 on: Fri, 28 November 2014, 21:07:30 »
In the specialty kit you should add one at 1.75 units long so it can be used as a short right shift if anyone wants to use this on a Pure layout.
FTFY
Offline skipped
« Reply #134 on: Fri, 28 November 2014, 21:44:30 »
Any chance of seeing an Ergodox kit? (with legends or not)
Offline engicoder
« Reply #135 on: Fri, 28 November 2014, 21:58:10 »
FTFY
I think he meant "Slang Kit" as the specialty kit already has 1.75u shift. I think he means "RIGHTEOUS" on a 1.75u
« Reply #136 on: Fri, 28 November 2014, 21:59:52 »
FTFY
Oh
well I'm cool with that if it's not expensive
Offline engicoder
« Reply #137 on: Fri, 28 November 2014, 22:20:51 »
There will be blanks offered, but haven't added an ErgoDox specific set yet.
Here is a couple mockups:
With existing set and blanks
82875-0
With an ErogDox Kit
82873-1
« Last Edit: Fri, 28 November 2014, 22:23:11 by engicoder »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #138 on: Fri, 28 November 2014, 22:31:38 »
With an ErogDox Kit
That ergodox set is pretty sick.  The standard is pretty awesome on an ergodox too (for the non-symmetrical look).
Offline engicoder
« Reply #139 on: Fri, 28 November 2014, 23:07:35 »
OP updated to add ErgoDox base and reverse gradient
Offline Data
« Reply #140 on: Sat, 29 November 2014, 00:59:18 »
With an ErogDox Kit
Heh, that worked out much better than I imagined.  I wasn't even considering this set for Ergodox.
Offline hjc1710
« Reply #141 on: Sat, 29 November 2014, 05:13:30 »
So much win in this GB... Very heavily interested. Good work all around so far.
Might want to change your sig though engicoder, it still calls the buy the "Garish Chocolatey Brown Set", give this set the proper sexy title it deserves!
Filco Majestouch II (B) | Poker II (BR) | Cherry G80-11900 (BLK) | Das V3 (BR) | RS84 (soon...)
Granite | Skull Squadron | Deep Space | Raindrop R2 | Hyperfuse GMK (soon...)
Offline Oobly
« Reply #142 on: Sat, 29 November 2014, 06:05:06 »
Schweeet! This set is looking better all the time! Nice work engicoder! The slang and ergodox kits are awesome.
Offline engicoder
« Reply #143 on: Sat, 29 November 2014, 22:28:30 »
Question for the ErgoDox folks:
The ErgoDox sets are mocked up in the OP using blanks for all the non-alphas keys. Are there specific legends that are commonly used that should be included? Looking around there was a lot of variation among ErgoDox layouts, so it seems questionable to include any that would add cost but not be useful for the majority of buyers.
The Deep Space GB had the following kit:
82971-0
Any of these seem good, or should we stick with blanks?
« Last Edit: Sun, 30 November 2014, 09:21:38 by engicoder »
Offline n0rvig
« Reply #144 on: Sun, 30 November 2014, 01:17:30 »
So down with this! Make it happen! Boogie!
Offline Zebadule
« Reply #145 on: Sun, 30 November 2014, 11:17:08 »
It's fairly common for the non-alpha keys to include those caps. The layouts can be very different, but as long as the set is all R3, then people have the freedom to re-arrange as needed (but you'd probably need to go with a single color, which means the same style of stripe wouldn't work). If you run it, definitely make sure that blanks are available too.
Other ErgoDox comments:
  • ErgoDox sets seem to have smaller order numbers on average, so adding multiple hand color options may make it harder for the sets to tip.
  • The reverse-stripe ErgoDox kit isn't Colemak compatible, but is my favorite.
Edit: Took a look at the sets again, changed comments a bit.
« Last Edit: Sun, 30 November 2014, 11:22:19 by Zebadule »
Offline skipped
« Reply #146 on: Sun, 30 November 2014, 11:22:06 »
In my opinion, the Granite ergodox set felt very inclusive of options:
The only difficulty is that the inside column is brown and the outside column is 'cyan'. I don't want to say you shouldn't add legends, because it would be pretty awesome, but I'm not sure the resulting kit would be flexible enough for many different layouts.
Edit: got ninja'd
I agree with Zebadule, I don't think the ergodox set can be split into two separate parts. At the moment, EVE only has like 10 ergodox kit orders and Deep Space has about 10 as well.
« Last Edit: Sun, 30 November 2014, 11:25:37 by skipped »
Offline engicoder
« Reply #147 on: Sun, 30 November 2014, 12:12:42 »
    I suppose the asymmetric layout on the ErgoDox probably doesn't have the same effect as on a straight board, given that the two hands may be separated and at an angle, so the all brown would be the one to eliminate.
    As far as Dvorak and Colemak, if the ErgoDox numbers are small, these two will have even less interest. These folks may have to make do with the standard Dvorak/Colemak kits plus blanks.
    Offline engicoder
    « Reply #148 on: Sun, 30 November 2014, 12:21:07 »
    If we eliminated the all brown right hand, then most of the 1.5u keys would be blue and the 2u would be brown. The 4 inner 1.5u would be the only real sacrifice.
    Question is whether include blanks in the base kit and have these caps with legends as an add-on or vice versa, where the blanks would be add-on and the caps with legends included in the base kit.
    Offline Data
    « Reply #149 on: Mon, 01 December 2014, 07:57:11 »
    Man, I think it's going to be super difficult to get a proper Ergodox kit on this set.   :(  The color stripe just adds too many variables.
